Perfecting Goofy Polls
Just a general purpose post to spot trends in building choices and highlight the most commonly used strategies. If you don’t have a goofy style robot, please refrain from inputting data. Although some information might translate to other designs, I’d like to keep this focused.
Goofy style robots are as follows
4m tank drive, 2m intake roller system, 1m tilting mechanism, 1m lift.
Ratio used on two (or mini-4) bar lift
  • 5:1 100rpm
  • 5:1 200rpm
  • 7:1 100rpm
  • 7:1 200rpm
  • Other
0 voters
Sprocket size and motor rpm of intake rollers
  • 100rpm 18back, 18front
  • 100rpm 18back, 24front
  • 100rpm 24back, 18front
  • 100rpm 24back, 24front
  • 200rpm 18back, 18front
  • 200rpm 18back, 24front
  • 200rpm 24back, 18front
  • 200rpm 24back, 24front
  • Other
0 voters
Type of roller
  • “China Rollers” 5:3:3
  • “China Rollers” 3:3:3
  • Chain, no hinge
  • Tank tread, no hinge
  • Chain, hinged
  • Double/triple chain, hinged
  • Tank tread, hinged
  • Other
0 voters
Roller deploy
  • Flip down
  • Flip out(sideways)
  • Flip up from under 2 bar(on hinge)
  • No flip
  • Other
0 voters
Drive gear ratio/motor rpm
There are other possible ratios, but I’m excluding <200, >1000. Select other if you don’t fall into the provided range. I’m also not including sprocket/gear combination ratios. Just choose closest matching ratio. If you run 1:1 600rpm for instance, select 1:3 200rpm.
  • 1:1 200rpm (200)
  • 1:3 100rpm (300)
  • 3:5 200rpm (333)
  • 1:2 200rpm (400)
  • 3:7 200rpm (466)
  • 1:5 100rpm (500)
  • 1:3 200rpm (600)
  • 1:7 100rpm (700)
  • 3:5 600rpm (1000)
  • Other
0 voters
Tilter ratio
  • 5:1 100rpm
  • 7:1 100rpm
  • 15:1 200rpm (7.5:1)
  • 21:1 200rpm (10.5:1)
  • 15:1 100rpm
  • 21:1 100rpm
  • Other
0 voters
Tray Mount
  • Hinged
  • Screw Joints
0 voters
Type of tray (referencing second stage and up)
  • Flip (2 stage)
  • Telescopic (2 stage)
  • Flip, Telescopic (3 stage)
  • Flip, Flip (3 stage)
  • Flip, Flip, Telescopic (4 stage)
  • Flip, Flip, Flip (4 stage)
  • Flip, Flip, Sketchy Lexan (4 stage)
  • Flip, Flip, Flip, Telescopic (5 stage)
  • Flip, Flip, Flip, Flip (5 stage)
  • Flip, Flip, Flip, Sketchy Lexan (5 stage)
  • Other
0 voters
Robot width(hole count)
  • 26 holes
  • 26 Holes
  • 25 Holes
  • 24 Holes
  • < 24 Holes
0 voters
If there’s anything big that I missed just lmk and Ill be happy to add/edit. For anyone confused about gear ratios, 12tooth = 1, 36tooth = 3, 60tooth = 5, 84tooth = 7. Hopefully these results prove interesting.
Does this account for any kinds of arm variety or is it just motor ratios?
This is mainly for 2 bar lifts, but a lot of teams have added small 4 bar structures to be able to easily rubber bands their 2 bars. Adding the mini-4 bar linkage also lowers the motor, which helps with center of gravity and subsequently tipping issues.
