Personal Vex Team Quotes
#161
Builds a mogo only robot with an 8 motor high speed chassis
“Here at 929S, we don’t push the limits of ourselves and our robot, but the limits of the other robots, by pushing and damaging them excessively!”
#162
Should’ve had an 8m torque geared 2:1 for speed, like 109A’s meme bot. It would push other bots like toys…
#163
I would’ve changed the ratio but it seems to be doing its job just fine
Also my build quality is questionable so I wasn’t quite sure if anything past HS would stall so :confused:
#164
“If the batteries are hot they are good” - my TL
#165
“What’s the difference between a Double reverse four bar, a DR4B, and a RD4B?” - My programmer in August
#166
Finds a part in the field after practice: well, it’s time to play the game called “where did this come from and is it important”
#167
@TheLordsChipsBuilder
Your signature has basically became EHS’s catchphrase when our parts fall off
#168
our #1 motto is “fail less”
#169
and if a bolt falls off even if I haven’t been on that side of the field everyone assumes it came from my robot
#170
“Guys we have a problem” - my team leader every 5 seconds
“Yeah this should work” - famous last words
#171
“Hey guys… this [insert crucial subsystem] doesn’t fit!”
#172
“Our robot is just a little outside the sizing box, It’ll be fine.” -Me everyday since we haven’t figured out how to make our rollers fit inside the size requirements
#173
I guess it is angle grinder time!
#174
use a belt grinder. that way you can just grind the whole robot at once, disintegrating everything that gets in the way until the robot is smaller than 18" x 18" x 18"
#175
Better yet, one of those huge industrial CNC routers. You can program it to make a perfect 17.9999 inch square out of your robot.
#176
My work has an industrial plasma cutter, it isn’t as accurate but we are actually using it for a secret idea
#177
Just before a match:
“Is the autonomous ready?”
“I don’t know, I just made some tweaks”
#178
Just after autonomous starts:
“Did you click the right autonomous?”
“I forgot to click the button”
#179
Teammate #1: “ half the robot is broken”
Teammate #2: “ it’s fine, just let me pick up cones”
#180
I didn’t realize the Physical Education teacher was also the Robotics advisor
