PID completely in-operational. Accounts to none
#pragma region VEXcode Generated Robot Configuration
// Make sure all required headers are included.
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <math.h>
#include <string.h>
#include "vex.h"
using namespace vex;
// Brain should be defined by default
brain Brain;
// START V5 MACROS
#define waitUntil(condition)                                                   \
  do {        \
    wait(5, msec);                                                             \
  } while (!(condition))
#define repeat(iterations)                                                     \
  for (int iterator = 0; iterator < iterations; iterator++)
// END V5 MACROS
// Robot configuration code.
controller Controller1 = controller(primary);
motor halfright = motor(PORT14, ratio18_1, true);
motor fullright = motor(PORT13, ratio18_1, false);
motor fullleft = motor(PORT17, ratio18_1, false);
motor halfleft = motor(PORT18, ratio18_1, true);
digital_out newmadkick = digital_out(Brain.ThreeWirePort.A);
digital_out newmadkick2 = digital_out(Brain.ThreeWirePort.B);
rotation rotate = rotation(PORT1, false);
digital_out Leftists = digital_out(Brain.ThreeWirePort.C);
digital_out Rightists = digital_out(Brain.ThreeWirePort.D);
motor RightB = motor(PORT2, ratio18_1, true);
motor RightA = motor(PORT3, ratio18_1, false);
motor LeftA = motor(PORT10, ratio18_1, false);
motor LeftB = motor(PORT5, ratio18_1, true);
// Helper to make playing sounds from the V5 in VEXcode easier and
// keeps the code cleaner by making it clear what is happening.
void playVexcodeSound(const char *soundName) {
  printf("VEXPlaySound:%s\n", soundName);
  wait(5, msec);
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
#pragma endregion VEXcode Generated Robot Configuration
//    Project: Reformed code
//    Author:
//    Created: 10/23/2023
//    Configuration: IDK what this means
// Include the V5 Library
#include <vex.h>
// Allows for easier use of the VEX Library
using namespace std;
// DECLARE VARIALBES:
//pre-auton
void preAutonomous(void) {
  // actions to do when the program starts
  Brain.Screen.clearScreen();
  Brain.Screen.print("pre auton code");
  wait(1, seconds);
double kP = 0.0004;
double kI = 0.0;
double kD = 0.0;
double TurnkP = 0.0;
double TurnkI = 0.0;
double TurnkD = 0.0;
int DesVal = 200;
int DesTurnVal = 0;
int error;
int previError = 0;
int derivative;
int totalError = 0;
int Turnerror;
int TurnpreviError = 0;
int Turnderivative;
int TurntotalError = 0;
bool MiH = false; //Resets the Drive sensors when true
bool enabledrivepid = true;
double LeftTotalDivided = (LeftB.position(degrees)+LeftA.position(degrees))/2;
double RightTotalDivided = (RightB.position(degrees)+RightA.position(degrees))/2;
int DrivePid(){
while(enabledrivepid){
    if (MiH){
      MiH = false;
      LeftTotalDivided = 0;
      RightTotalDivided = 0;
  double AvgPos = (RightTotalDivided + LeftTotalDivided)/2;
  error = AvgPos - DesVal;
  derivative = error - previError; //What else would a derivative be? I know you aren't special, so I don't need to specify.
  //Integral of Velocity is Pos. Integral of Pos is absolute Pos in a given state of time, known as Absement.
  totalError += error;
  double LatMotorPower = error * kP + derivative * kD + totalError * kI;
//turn CONTROL
 double TurnDiff = RightTotalDivided - LeftTotalDivided;
  Turnerror = TurnDiff - DesTurnVal;
  Turnderivative = Turnerror - TurnpreviError; //What else would a derivative be? I know you aren't special, so I don't need to specify.
  TurntotalError += Turnerror;
  double THISISPOWER = Turnerror * TurnkP + Turnderivative * TurnkD + TurntotalError * TurnkI;
LeftA.spin(forward, LatMotorPower + THISISPOWER, voltageUnits::volt);
LeftB.spin(forward, LatMotorPower + THISISPOWER, voltageUnits::volt);
RightA.spin(reverse, LatMotorPower - THISISPOWER, voltageUnits::volt);
RightB.spin(reverse, LatMotorPower - THISISPOWER, voltageUnits::volt);
previError = error;
TurnpreviError = Turnerror;
vex::task::sleep(20);
return 1;
void autonomous(void) {
  MiH = true;
  Brain.Screen.print("autonomous code");
  // place automonous code here
  vex::task think2xmorethanyoubuild(DrivePid);
  DesVal = 100;
  DesTurnVal = 600;
  vex::task::sleep(2000);
  MiH = true;
  DesVal = 100;
  DesTurnVal = 600;
void userControl(void) {
  // place driver control in this while loop
  while (true) {
    wait(20, msec);
    //enabledrivepid = false;
    //driveTrain();
    LeftA.spin(forward, Controller1.Axis3.position() + Controller1.Axis1.position(), pct);
    LeftB.spin(forward, Controller1.Axis3.position() + Controller1.Axis1.position(), pct);
    RightB.spin(reverse, Controller1.Axis3.position() - Controller1.Axis1.position(), pct);
    RightA.spin(reverse , Controller1.Axis3.position() - Controller1.Axis1.position(), pct);
  //intake
int main() {
  // create competition instance
  competition Competition;
  // Set up callbacks for autonomous and driver control periods.
  Competition.drivercontrol(userControl);
  // Run the pre-autonomous function.
  preAutonomous();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
In the end, it does none. Motors fail to run entirely. Why may this be the case?
Your kp is .0004 and your target is 200. This means that the initial power will be 0.08 volts which translates to 0.66 pct which explains your problem. Maybe start with kp = 0.5 and adjust from there
