PID continuously running, even past des value, and without proportion
#pragma region VEXcode Generated Robot Configuration
// Make sure all required headers are included.
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <math.h>
#include <string.h>
#include "vex.h"
using namespace vex;
// Brain should be defined by default
brain Brain;
// START V5 MACROS
#define waitUntil(condition)                                                   \
  do {        \
    wait(5, msec);                                                             \
  } while (!(condition))
#define repeat(iterations)                                                     \
  for (int iterator = 0; iterator < iterations; iterator++)
// END V5 MACROS
// Robot configuration code.
controller Controller1 = controller(primary);
motor halfright = motor(PORT14, ratio18_1, true);
motor fullleft = motor(PORT17, ratio18_1, false);
motor halfleft = motor(PORT18, ratio18_1, true);
digital_out newmadkick = digital_out(Brain.ThreeWirePort.A);
digital_out newmadkick2 = digital_out(Brain.ThreeWirePort.B);
rotation rotate = rotation(PORT1, false);
digital_out Leftists = digital_out(Brain.ThreeWirePort.C);
digital_out Rightists = digital_out(Brain.ThreeWirePort.D);
motor LeftA = motor(PORT19, ratio6_1, false);
motor LeftB = motor(PORT9, ratio6_1, false);
motor RightA = motor(PORT12, ratio6_1, false);
motor RightB = motor(PORT13, ratio6_1, false);
// Helper to make playing sounds from the V5 in VEXcode easier and
// keeps the code cleaner by making it clear what is happening.
void playVexcodeSound(const char *soundName) {
  printf("VEXPlaySound:%s\n", soundName);
  wait(5, msec);
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
#pragma endregion VEXcode Generated Robot Configuration
//    Project: Reformed code
//    Author:
//    Created: 10/23/2023
//    Configuration: guh
// Include the V5 Library
#include <vex.h>
// Allows for easier use of the VEX Library
using namespace std;
// DECLARE VARIALBES:
//pre-auton
void preAutonomous(void) {
  // actions to do when the program starts
  Brain.Screen.clearScreen();
  Brain.Screen.print("pre auton code");
  wait(1, seconds);
double kP = 0.06;
double kI = 0.0;
double kD = 0.0;
double TurnkP = 0.0;
double TurnkI = 0.0;
double TurnkD = 0.0;
int DesVal;
int DesTurnVal;
int error;
int previError = 0;
int derivative;
int totalError = 0;
int Turnerror;
int TurnpreviError = 0;
int Turnderivative;
int TurntotalError = 0;
bool MiH = false; //Resets the Drive sensors when true
bool enabledrivepid = true;
double LeftTotalDivided = (LeftB.position(degrees)+LeftA.position(degrees))/2;
double RightTotalDivided = (RightB.position(degrees)+RightA.position(degrees))/2;
int DrivePid() {
    while (enabledrivepid) {
        if (MiH) {
            MiH = false;
            LeftTotalDivided = 0;
            RightTotalDivided = 0;
        double AvgPos = (RightTotalDivided + LeftTotalDivided) / 2;
        error = DesVal - AvgPos;  // Correct the error calculation
        derivative = error - previError;
        totalError += error;
        double LatMotorPower = error * kP + derivative * kD + totalError * kI;
        double TurnDiff = RightTotalDivided - LeftTotalDivided;
        Turnerror = DesTurnVal - TurnDiff;  // Correct the Turnerror calculation
        Turnderivative = Turnerror - TurnpreviError;
        TurntotalError += Turnerror;
        double THISISPOWER = Turnerror * TurnkP + Turnderivative * TurnkD + TurntotalError * TurnkI;
        // Debugging statements
        Brain.Screen.printAt(10, 20, "AvgPos: %.2f", AvgPos);
        Brain.Screen.printAt(10, 40, "Error: %.2f", error);
        Brain.Screen.printAt(10, 60, "TurnDiff: %.2f", TurnDiff);
        Brain.Screen.printAt(10, 80, "TurnError: %.2f", Turnerror);
        LeftA.spin(forward, LatMotorPower + THISISPOWER, voltageUnits::volt);
        LeftB.spin(forward, LatMotorPower + THISISPOWER, voltageUnits::volt);
        RightA.spin(reverse, LatMotorPower - THISISPOWER, voltageUnits::volt);
        RightB.spin(reverse, LatMotorPower - THISISPOWER, voltageUnits::volt);
        previError = error;
        TurnpreviError = Turnerror;
        vex::task::sleep(20);  // Adjust sleep duration if needed
    // Stop the motors when the PID loop is disabled
    LeftA.stop();
    LeftB.stop();
    RightA.stop();
    RightB.stop();
    return 1;
void autonomous(void) {
  vex::task think2xmorethanyoubuild(DrivePid);
  MiH = true;
  Brain.Screen.print("autonomous code");
  // place automonous code here
  DesVal = 1;
  vex::task::sleep(2000);
  MiH = true;
  DesVal = 100;
  DesTurnVal = 600;
void userControl(void) {
  // place driver control in this while loop
  while (true) {
    wait(20, msec);
    //enabledrivepid = false;
    //driveTrain();
    LeftA.spin(forward, Controller1.Axis3.position() + Controller1.Axis1.position(), pct);
    LeftB.spin(forward, Controller1.Axis3.position() + Controller1.Axis1.position(), pct);
    RightB.spin(reverse, Controller1.Axis3.position() - Controller1.Axis1.position(), pct);
    RightA.spin(reverse , Controller1.Axis3.position() - Controller1.Axis1.position(), pct);
  //intake
int main() {
  // create competition instance
  competition Competition;
  // Set up callbacks for autonomous and driver control periods.
  Competition.drivercontrol(userControl);
  //vex::task think2xmorethanyoubuild(DrivePid);
  // Run the pre-autonomous function.
  preAutonomous();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
Are there any clear issues?
Your PID is fine, but you need to update LeftTotalDivided and RightTotalDivided in the loop, because it is only set at the beginning of the program meaning that the PID doesn’t know the robot is moving.
