PID Control Programming Help in RobotC
Hi, I’m a novice programmer and I need some help programming open-loop PID control incorporated with my arcade drive code. I have a functioning arcade drive drive train that works well enough, but I want to take the extra step and implement open-loop PID control. The robot is for a small competition for my robotics class so I do not have encoders or sensors. I do not have access to the robot for a couple weeks but I’d like to have something that will work in theory because I’m on a huge time crunch (cough hardware issues cough). This is what I currently have:
#pragma config(Motor,  port2,           leftMotor,     tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port3,           rightMotor,    tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port5,           leftLift,      tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port6,           rightLift,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port7,           centerLift,    tmotorVex393_MC29, openLoop)
//set variables for arcade drive
int maxPower = 127;
int minPower = -127;
int deadband = 5;
// Set constants for the PID control loop
const float kp = 0.5;  // Proportional gain
const float ki = 0.1;  // Integral gain
const float kd = 0.1;  // Derivative gain
// Set the target speed for the motors
const float targetSpeed = 50;  // Target speed in RPM
// Set variables for the PID control loop
float error = 0;         // Error value
float integral = 0;      // Integral term
float derivative = 0;    // Derivative term
float previousError = 0; // Previous error value
task main()
	while(1 == 1){
		//Calculates motor power
		float leftPower = (vexRT[Ch2] + vexRT[Ch1]);
		float rightPower = (vexRT[Ch2] - vexRT[Ch1]);
		// check calculated amount against min/max
		if (rightPower > maxPower) {
			rightPower = maxPower;
		else if (rightPower < minPower){
			rightPower = minPower;
		if (leftPower > maxPower) {
			leftPower = maxPower;
		else if (leftPower < minPower) {
			leftPower = minPower;
		//ignores values within deadband range
		if (abs(leftPower) < deadband ) leftPower = 0;
		if (abs(rightPower) < deadband ) rightPower = 0;
		//sets motor power
		motor[leftMotor]  = leftPower;
		motor[rightMotor] = rightPower;
		//center lift motor up
		if(vexRT[Btn6U] == 1) {
			motor[centerLift] = 55;
		//center lift motor down
		else if(vexRT[Btn6D] == 1) {
			motor[centerLift] = -35;
		else {
			motor[centerLift] = 0;
		//lift main lift up
		if (vexRT[Btn5U] == 1) {
			motor[leftLift] = 65;
			motor[rightLift] = 65;
		//drop main lift
		else if (vexRT[Btn5D] == 1) {
			motor[leftLift] = -40;
			motor[rightLift] = -40;
		//If buttons are not pressed, nothing happens
		else{
			motor[leftLift] = 0;
			motor[rightLift] = 0;
		// Calculate the error between the current speed and the target speed
		error = targetSpeed - getMotorVelocity(leftMotor);
		error = targetSpeed - getMotorVelocity(rightMotor);
		// Update the integral term
		integral += error;
		// Calculate the derivative term
		derivative = error - previousError;
		// Calculate the output value for the PID control loop
		float output = (kp * error) + (ki * integral) + (kd * derivative);
		// Set the motor speeds using the output value
		setMotorSpeed(leftMotor, output);
		setMotorSpeed(rightMotor, output);
		// Update the previous error value
		previousError = error;
		// Wait for a short time before iterating the loop again
		wait1Msec(25);
All the non PID code is functional. Everything else compiles but I haven’t tested at all and is likely very incorrect. Any help is greatly appreciated, even anything with the way my code is organized or commented. Thank you!
