Hi, we have been trying to implement a drive PID into our auto, but have ran into a problem.
The problem is when I want to reset the drive motors back to 0 with the resetDriveSensors
to start a new forward movement it starts to turn to the left instead of moving straight.
The code listed below is what we have.
double kP = 0.073;
//double kI = 0.0;
double kD = 0.04;
double turnkP = 0.073;
//double turnkI = 0.0;
double turnkD = 0.04;
//Autonomous Settings
int desiredValue = 200;
int desiredTurnValue = 0;
double error = 0; //SensorValue - DesiredValue : Position
double prevError = 0; //Position 20 miliseconds ago
double derivative= 0; // error - prevError : Speed
//double totalError = 0; //totalError = totalError + error
double turnError= 0; //SensorValue - DesiredValue : Position
double turnPrevError = 0; //Position 20 miliseconds ago
double turnDerivative= 0; // error - prevError : Speed
//int turnTotalError = 0; //totalError = totalError + error
bool resetDriveSensors = false;
//Variables modified for use
bool enableDrivePID = true;
int drivePID(){
while(enableDrivePID){
if (resetDriveSensors) {
rightB.resetPosition();
rightF.resetPosition();
rightM.resetPosition();
leftM.resetPosition();
leftB.resetPosition();
leftF.resetPosition();
rightB.setPosition(0,degrees);
rightF.setPosition(0,degrees);
rightM.setPosition(0,degrees);
leftM.setPosition(0,degrees);
leftF.setPosition(0,degrees);
leftB.setPosition(0,degrees);
//Get the position of both motors
double leftfrontPosition = leftB.position(degrees);
double leftmiddlePosition = leftM.position(degrees);
double leftbackPosition = leftF.position(degrees);
double rightBackMotorPosition = rightB.position(degrees);
double rightmiddleMotorPosition = rightM.position(degrees);
double rightfrontMotorPosition = rightF.position(degrees);
//Lateral movement PID
//Get average of the six motors
double averagePosition = ( (leftfrontPosition + leftmiddlePosition + leftbackPosition + rightBackMotorPosition + rightmiddleMotorPosition + rightfrontMotorPosition)/6);
//Potential
error = desiredValue - averagePosition ;
//Derivative
derivative = error - prevError;
//integral
//totalError += error;
double lateralMotorPower = (error * kP + derivative * kD)/12.0; //+ totalError * kI;
//Turning movement PID
double turnDifference = leftmiddlePosition - rightmiddleMotorPosition;
//Potential
turnError = desiredTurnValue - turnDifference;
//Derivative
turnDerivative = turnError - turnPrevError;
//Integral
//turnTotalError += turnError;
double turnMotorPower = (turnError * turnkP + turnDerivative * turnkD)/12.0; //+ turnTotalError * turnkI;
rightF.spin(forward, lateralMotorPower - turnMotorPower, voltageUnits::volt);
rightB.spin(forward, lateralMotorPower - turnMotorPower, voltageUnits::volt);
rightM.spin(forward, lateralMotorPower - turnMotorPower, voltageUnits::volt);
leftF.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
leftB.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
leftM.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
prevError = error;
turnPrevError = turnError;
vex::task::sleep(20);
return 1;
when called in auto
void autonomous(void) {
vex::task that(drivePID);
resetDriveSensors = true;
desiredValue = 600
desiredTurnValue = 1300;
vex::task::sleep(2000);
desiredValue = 1300;
Any advice and help would be great.
