Hi , I had a question on how to use thresholds, and timestops in my PID loop so that I can tune it properly and get an autonomous working
void pre_auton(void) {
// Initializing Robot Configuration.
vexcodeInit();
double kP = -0.05;
double kI = -0.0;
double kD = -0.07;
double turnkP = -0.5;
double turnkI = -0.0;
double turnkD = -0.5;
int maxTurnIntegral = 300; // These cap the integrals
int maxIntegral = 300;
int integralBound = 3; //If error is outside the bounds, then apply the integral. This is a buffer with +-integralBound degrees
//Autonomous Settings
int desiredValue = 0;
int desiredTurnValue = 0;
int error; //SensorValue - DesiredValue : Position
int prevError = 0; //Position 20 miliseconds ago
int derivative; // error - prevError : Speed
int totalError = 0; //totalError = totalError + error
int turnError; //SensorValue - DesiredValue : Position
int turnPrevError = 0; //Position 20 miliseconds ago
int turnDerivative; // error - prevError : Speed
int turnTotalError = 0; //totalError = totalError + error
bool resetDriveSensors = false;
//Variables modified for use
bool enableDrivePID = true;
//Pasted from a C++ resource
double signnum_c(double x) {
if (x > 0.0) return 1.0;
if (x < 0.0) return -1.0;
return x;
int drivePID(){
while(enableDrivePID){
if (resetDriveSensors) {
Leftfront.setPosition(0,degrees);
Rightfront.setPosition(0,degrees);
Leftback.setPosition(0,degrees);
Rightback.setPosition(0,degrees);
//Get the position of four motors
int leftfrontMotorPosition = Leftfront.position(degrees);
int rightfrontMotorPosition = Rightfront.position(degrees);
int rightbackMotorPosition = Rightback.position(degrees);
int leftbackMotorPosition = Leftback.position(degrees);
//Lateral movement PID
//Get average of the four motors
int averagePosition = (leftfrontMotorPosition + rightfrontMotorPosition + leftbackMotorPosition + rightbackMotorPosition)/4;
//Potential
error = averagePosition - desiredValue;
//Derivative
derivative = error - prevError;
//Integral
if(abs(error) < integralBound){
totalError+=error;
} else {
totalError = 0;
//totalError += error;
//This would cap the integral
totalError = abs(totalError) > maxIntegral ? signnum_c(totalError) * maxIntegral : totalError;
double lateralMotorPower = error * kP + derivative * kD ;
//Turning movement PID
//Get average of the two motors
int turnDifference = leftfrontMotorPosition && leftbackMotorPosition - rightbackMotorPosition && rightfrontMotorPosition;
//Potential
turnError = turnDifference - desiredTurnValue;
//Derivative
turnDerivative = turnError - turnPrevError;
//Integral
turnTotalError+=turnError;
} else {
turnTotalError = 0;
//turnTotalError += turnError;
turnTotalError = abs(turnTotalError) > maxIntegral ? signnum_c(turnTotalError) * maxIntegral : turnTotalError;
double turnMotorPower = turnError * turnkP + turnDerivative * turnkD + turnTotalError * turnkI;
Leftfront.spin(forward, lateralMotorPower + turnMotorPower , voltageUnits::volt);
Leftback.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
Rightfront.spin(forward, lateralMotorPower - turnMotorPower , voltageUnits::volt);
Rightback.spin(forward, lateralMotorPower - turnMotorPower , voltageUnits::volt);
prevError = error;
turnPrevError = turnError;
vex::task::sleep(20);
return 1;
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
vex::task billWiTheScienceFi(drivePID);
resetDriveSensors = true;
desiredValue = 1000;
vex::task::sleep(1000);
desiredValue = -1000;
