Hi, I followed @Connor 's tutorial and I’m stumped.
When I start the program, nothing happens, but when I start to turn the robot manually, it picks up forward speed and makes no effort to correct its self. it also completely ignores the desired value. The more I turn it away from its original position, the more speed it has.
I’ve also tested the turning part of the PID (I replaced the desiredValue with desiredTurnValue). When I started the code, it just drove forward.
The ‘desiredValue’ is so small because I was just changing the value to random numbers to see if it would make a difference and it didn’t.
Please take a look and see if you can find my mistakes.
rightDrive = right side of robots drivetrain (two motors grouped together)
leftDrive = left side of robots drivetrain (two motors grouped together)
VEXcode Pro V5:
// Robot Configuration:
// [Name] [Type] [Port(s)]
// rightDrive motor_group 12, 13
// leftDrive motor_group 18, 19
// Inertial inertial 15
#include “vex.h”
using namespace vex;
void pre_auton(void) {
vexcodeInit();
double kP = 0.0001;
double kI = 0;
double kD = 0;
double turnkP = 0.5;
double turnkI = 0.0;
double turnkD = 0.0;
int desiredValue = 200;
int desiredTurnValue = 0;
int error; //SensorValue - DesiredVaule : Position
int prevError = 0; //Position 20 msecs ago
int derivative; // error - prevError : Speed
int totalError = 0; //totalError = totalError + error
int turnError; //SensorValue - DesiredValue : Position
int turnPrevError = 0;//Position 20 msecs ago
int turnDerivative; // error - prevError : Speed
int turnTotalError = 0; //totalError = totalError + error
bool resetDriveSensors = false;
//variables (modifiable)
bool enableDrivePID = true;
int drivePID(){
while(enableDrivePID){
if (resetDriveSensors) {
leftDrive.setPosition(0, degrees);
rightDrive.setPosition(0, degrees);
//Lateral Movement PID
//Average
int averagePosition = (leftDrive.position(degrees) + rightDrive.position(degrees))/2;
//Potential
error = desiredValue - averagePosition;
//Derivative
derivative = error - prevError;
//Integral
totalError += error;
double lateralMotorPower = error * kP + derivative * kD + totalError * kI;
//Turning
//Potential
turnError = desiredTurnValue - Inertial.rotation(deg);
//Derivative
turnDerivative = turnError - turnPrevError;
//Integral
//turnTotalError += turnError;
double turnMotorPower = turnError * turnkP + turnDerivative * turnkD + turnTotalError * turnkI;
rightDrive.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
leftDrive.spin(forward, lateralMotorPower - turnMotorPower, voltageUnits::volt);
rightDrive.setStopping(brake);
leftDrive.setStopping(brake);
prevError = error;
turnPrevError = turnError;
vex::task::sleep(20);
return 1;
void autonomous(void) {
// Insert autonomous user code here.
vex::task MainFunction(drivePID);
resetDriveSensors = true;
desiredValue = 10;
vex::task::sleep(1000);
int main() {
