PID on Vex Code Making unlimited turns
We met the same question as yours that we setup the PstraightForward code and it works great. But when we setup the PstraightReverse code, it goes back forever. The reverse code is exactly the same as the forward code except for the motors spin reverse. Do you have any suggestions? Thanks.
I’m having the same issue with my turning loop which seems to not be changing the error at all. Here is the code:
#Function to turn
def turn_to(TARGET):
    #Creates all the local variables
    ERROR = 0
    LASTERROR = 0
    TOTALERROR = 0
    OUTPUT = 0
    START = time.time()
    #Define starting variables
    TOL = 1
    TIME = 3
    INT_RANGE = 10
    while True:
        ERROR = TARGET - brain_inertial.rotation()
        if ERROR > 180:
            ERROR -= 360
        elif ERROR < -180:
            ERROR += 360
        brain.screen.print(brain_inertial.rotation())
        brain.screen.next_row()
        if abs(ERROR) < TOL:
            brain.play_sound(SoundType.SIREN)
            break
        if time.time() - START > TIME:
            break
        if abs(ERROR) < abs(TOTALERROR):
            break
        TOTALERROR += ERROR
        TOTALERROR = max(min(TOTALERROR, INT_RANGE), -INT_RANGE)
        P = ERROR * turnkp
        I = TOTALERROR * turnti
        D = (ERROR - LASTERROR) * turntd
        OUTPUT = P+I+D
        left_drive.set_velocity(-OUTPUT, RPM)
        right_drive.set_velocity(OUTPUT, RPM)
        left_drive.spin(FORWARD)
        right_drive.spin(FORWARD)
        LASTERROR = ERROR
        wait(20,MSEC)
    left_drive.stop()
    right_drive.stop()
