PID only turns right
Hello so I made this PID and it uses a global rotation variable but when its global it only turns right. When the variable is reset at the start of each loop it works just fine but I need it more accurate than that.
def turn_to_angle(target_angle, direction):
    global error, integral, derivative, previous_error
    # Reset PID variables
    error = 0
    integral = 0
    derivative = 0
    previous_error = 0
    consecutive_stable_iterations = 0
    Time = 3
    TimeStop = 50
    # Main PID loop for turning
    while True:
        current_angle = inertial_10.rotation(DEGREES)
        error = target_angle - current_angle
        if  error < 0 :
            intergral = 0
        derivative = error - previous_error
        previous_error = error
        output = kp2 * error + ki2 * integral + kd2 * derivative
        speed = abs(output)
        if error > 1:
            left_speed2 = 1 * speed
            right_speed2 = -1 * speed
        if error < -1:
            left_speed2 = -1 * speed
            right_speed2 = 1 * speed
        if abs(error) < 3:
            consecutive_stable_iterations += 1
        else:
        # Check for stability
        if consecutive_stable_iterations >=Time:
            LeftDrive1111.stop()
            LeftDrive1155.stop()
            RightDrive1111.stop()
            RightDrive1155.stop()
            break
        if TimeStop == 1:
            wait(3, SECONDS)
            break
        # Set motor velocities
        LeftDrive1111.spin(FORWARD, left_speed2, VOLT)
        LeftDrive1155.spin(FORWARD, left_speed2, VOLT)
        RightDrive1111.spin(FORWARD, right_speed2, VOLT)
        RightDrive1155.spin(FORWARD, right_speed2, VOLT)
        # Sleep for a short time to avoid excessive loop execution
        wait(10, MSEC)
Also it would be preferable if there was a way to choose the turning direction rather than it turning to the closest point but currently I haven’t gotten either to work.
