PID Problem
Hi
I am having problems with this PID program. I am not sure if it is the actual PID or the way that I have started the task or something else. I appreciate any advice or any problems in the program. Thank you. #pragma config(I2C_Usage, I2C1, i2cSensors)
#pragma config(Sensor, I2C_1, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Sensor, I2C_2, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Motor, port1, rightshooter1, tmotorVex393HighSpeed_HBridge, openLoop)
#pragma config(Motor, port2, rightshooter2, tmotorVex393HighSpeed_MC29, openLoop, encoderPort, I2C_1)
#pragma config(Motor, port3, rightback, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port4, rightfront, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port5, intake1, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, intake2, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port7, leftfront, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, leftback, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port9, leftshooter2, tmotorVex393HighSpeed_MC29, openLoop, reversed, encoderPort, I2C_2)
#pragma config(Motor, port10, leftshooter1, tmotorVex393HighSpeed_HBridge, openLoop, reversed)
#pragma platform(VEX)
//Competition Control and Duration Settings’
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
#include “Vex_Competition_Includes.c” //Main competition background code…do not modify!
//global variables
float rpsL;
float rpsR;
float virtualspeed;
float shootingspeed;
float rotationsL;
float rotationsR;
float timeval;
//gloabal variables for PID
int shooterspeedL; //power sent to left motors
int shooterspeedR; //power sent to right motors
float shooterfactor;
float target; //stores desired speed
float ticksL; //ticks of left Motor Encoder
float ticksR; //ticks of right Motor Encoder
float time = time1[T1] / 1000; //stores the elapsed time value
float velocityL; //velocity for left side
float velocityR; //velocity for right side
float errorL; //error for left side
float errorR; //error for right side
float errorTL; //total error for left side
float errorTR; //total error for right side
float proportionL; //value of proportional term for left side
float proportionR;//value of proportional term for right side
float integralL; //value of integral term for left side
float integralR;//value of integral term for right side
float derivitiveL; //value of derivative term for left side
float derivitiveR;//value of derivitive term for right side
float integralActiveZone = 400; //value in which the integral term is active
float lastErrorL; //stores previous error for left side
float lastErrorR; //stores previous error for right side
float Kp = .001;
float Ki = 0;
float Kd = 0;
task velocity_control() {
while(true) {
	nMotorEncoder[leftshooter2] = 0;//clear the encoders
	nMotorEncoder[rightshooter2] = 0;//clear the encoders
	clearTimer(T1);
	ticksL = nMotorEncoder[leftshooter2];
	ticksR = nMotorEncoder[rightshooter2];
	rotationsL = ticksL / 392;
	rotationsR = ticksR / 392;
	velocityL = (rotationsL / time) * ((49 / 3) * 1.6);
	velocityR = (rotationsR / time) * ((49 / 3) * 1.6);
	errorL = target - velocityL;
	errorR = target - velocityR;
	if(errorL<integralActiveZone && errorL != 0) {
		errorTL += errorL;
	else {
		errorTL = 0;
	if(errorR<integralActiveZone && errorR != 0) {
		errorTR += errorR;
	else {
		errorTR = 0;
	if(errorTL > 50/Ki) {
		errorTL = 50/Ki;
	if(errorTR > 50/Ki) {
		errorTR = 50/Ki;
	if(errorL == 0) {
		derivitiveL = 0;
	if(errorR == 0) {
		derivitiveR = 0;
	proportionL = errorL * Kp;
	proportionR = errorR * Kp;
	integralL = errorTL * Ki;
	integralR = errorTR * Ki;
	derivitiveL = (errorL - lastErrorL) * Kd;
	derivitiveR = (errorR - lastErrorR) * Kd;
	lastErrorL = errorL;
	lastErrorR = errorR;
	shooterspeedL = proportionL + integralL + derivitiveL;
	shooterspeedR = proportionR + integralR + derivitiveR;
	motor[leftshooter1] = motor[leftshooter2] = shooterspeedL;
	motor[rightshooter1] = motor[rightshooter2] = shooterspeedR;
// Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
// Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
//clearTimer(T1);
//launch();
shoot();
// User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol() {
while (true)
startTask(velocity_control);
slaveMotor(intake1, intake2);
	while(vexRT[Btn5U] == 1) {
		motor[leftfront] = motor[leftback] = vexRT[Ch2];
		motor[rightfront] = motor[rightback] = vexRT[Ch3];
	motor[leftfront] = motor[leftback] = vexRT[Ch3];
	motor[rightfront] = motor[rightback] = vexRT[Ch2];
	if(vexRT[Btn5UXmtr2] == 1) {
		motor[intake1] = -80;
		motor[intake2] = -80;
	else if(vexRT[Btn5DXmtr2] == 1) {
		motor[intake1] = 80;
		motor[intake2] = 80;
	else {
		motor[intake1] = 0;
		motor[intake2] = 0;
	slaveMotor(rightshooter1, rightshooter2);
	slaveMotor(leftshooter1, leftshooter2);
	if(vexRT[Btn8RXmtr2] ==1) {
	target = 500;
	else if(vexRT[Btn8UXmtr2] ==1) {
	else if(vexRT[Btn8LXmtr2] ==1) {
	else if(vexRT[Btn8DXmtr2] == 1) {
	else {
		target = 0;
Work on the velocity calculation code first, without the velocity being calculated correctly nothing else will work. This code
clearTimer(T1);
Should probably be changed to something like this.
  // Clear everything
  clearTimer(T1);
  // Wait so that the encoders can count
  wait1Msec(25);
  // now read the encoders and time
  time = time1 T1 ];
  // convert to rotations
  rotationsL = ticksL / 392.0;
  rotationsR = ticksR / 392.0;
  // make sure time is not 0 (which it really won't be)
  // and convert to rotations/second at the flywheel
  if( time != 0 ) {
  else {
    velocityL = velocityR = 0;
