PID Program not working
Hello, I am new to programming as of this year and I have been working on a PD loop for the drive of our robot. The problem I am running into is that the robot will go to the first value that I put in, but it will not continue onto the next value.
#include “vex.h”
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions /
You may want to perform some actions before the competition starts. /
Do them in the following function. You must return from this function /
or the autonomous and usercontrol tasks will not be started. This /
function is only called once after the V5 has been powered on and /
not every time that the robot is disabled. /
void preauton() {
vexcodeInit();}
//settiings
double kP=0.0309;
double kD=0.013;
double error =0.0;
double prevError = 0.0;
double derivative = 0.0;
bool running= true;
void drivePID(double target) {
while (running){
double LeftPosition=LeftEncoder.position(deg);
double RightPosition=RightEncoder.position(deg);
double averagePosition = (LeftPosition+RightPosition)/2;
  error = target-averagePosition;
  derivative= error-prevError;
  int lateralPower= kP*error + kD*derivative;
  FR.spin(fwd,lateralPower,voltageUnits::volt);
  BR.spin(fwd,lateralPower,voltageUnits::volt);
  FL.spin(fwd,lateralPower,voltageUnits::volt);
  BL.spin(fwd,lateralPower,voltageUnits::volt);
  Brain.Screen.print("error:");
  Brain.Screen.print(error);
  Brain.Screen.newLine();
  vex::task::sleep(10);
return ;}
// Example: clearing encoders, setting servo positions, …
Autonomous Task /
This task is used to control your robot during the autonomous phase of /
a VEX Competition. /
You must modify the code to add your own robot specific commands here. /
void autonomous(void) {
running=true;
drivePID(1000);
//reset encoders
RightEncoder.resetRotation();
LeftEncoder.resetRotation();
drivePID(300);
For future reference, please put you code in [code] [/code] tags
It looks like your while(running) loop might be stuck in an infinite loop because running is always true
You will have to make it so that running becomes false eventually. I think the best way of doing this is to make running false after error has been a sufficiently small value after a certain amount of time.
It would look something like this:
int timesWithinRange = 0;
//Set running to be true so that the loop runs
running = true;
while(running){
  if(std::abs(error) <= 2/*<<the error max value*/){
    timesWithinRange++;
  else {
  running = timesWithinRange < 10; /* the amount of time (in loop iterations) that you want the error to be small */
Hello,
Thanks for the help. It did solve the problem of the PID loop continuing onto the next command. However, at the end of commands the robot will turn randomly and I do not know why.
   #include "vex.h"
    #include <cmath>
[//settiings
double kP=0.0309;
double kD=0.005;
double turnkP=0.09;
double turnkD= 0.007;
double error =0.0;
double TurnError=0.0;
double prevTurnError=0.0;
double TurnDerivative=0.0;
bool running= true;
void drivePID(double target,double turnTarget) {
      bool enabled=true;
      while(enabled){
        double LeftPosition=Left.position(deg);
        double RightPosition=Right.position(deg);
      int TurnDifference = RightPosition-LeftPosition;
        TurnError= turnTarget - TurnDifference;
        TurnDerivative= TurnError-prevTurnError;
        int TurnMotorPower = (TurnError*turnkP + TurnDerivative*turnkD);
        FR.spin(fwd,lateralPower+TurnMotorPower,voltageUnits::volt);
        BR.spin(fwd,lateralPower+TurnMotorPower,voltageUnits::volt);
        FL.spin(fwd,lateralPower-TurnMotorPower,voltageUnits::volt);
        BL.spin(fwd,lateralPower-TurnMotorPower,voltageUnits::volt);
        Brain.Screen.print("TurnError");
        Brain.Screen.print(TurnError);
        if (std::abs(error)<5) {
          break;
          enabled = false;
      return;
  int reset(){
    Right.resetRotation();
    Left.resetRotation();
    return 0;}
  //task PIDTask = task(drivePID);
  running=true;
  ML.spinFor(reverse,0.5,rev);
  drivePID(2000,-480);
  reset();
  drivePID(2800,0);
  reset
vex::task::sleep(1000);
