PID speed control problem
Hi, I am newbie to Robotc. I try to use the internal PID. But I now can’t change motor speed after PID is enabled using Motor and Sensor Configuration – the motor always run on the same speed even if I change the value of motor] in launchBallLeft task. May someone help me?
#pragma config(Sensor, dgtl1,  mode1,          sensorDigitalIn)
#pragma config(Sensor, dgtl2,  mode2,          sensorDigitalIn)
#pragma config(Sensor, I2C_1,  ,               sensorQuadEncoderOnI2CPort,    , AutoAssign )
#pragma config(Sensor, I2C_2,  ,               sensorQuadEncoderOnI2CPort,    , AutoAssign )
#pragma config(Motor,  port2,           baseR,         tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port3,           baseR,         tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port4,           lift1,         tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor,  port5,           launch1,       tmotorVex393TurboSpeed_MC29, PIDControl, reversed, encoderPort, I2C_1)
#pragma config(Motor,  port6,           launch2,       tmotorVex393TurboSpeed_MC29, PIDControl, encoderPort, I2C_2)
#pragma config(Motor,  port7,           grab,          tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port8,           bassL,         tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port9,           baseL,         tmotorVex393_MC29, openLoop)
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
#include "Vex_Competition_Includes.c"   //Main competition background code...do not modify!
//                          Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
int firstSpeed;
int secondSpeed;
int thirdSpeed;
int V1;
void setSpeed(int a, int b, int c){
	firstSpeed = a;
	secondSpeed = b;
	thirdSpeed = c;
task baseControl(){
	while(true){
		motor[port2] = vexRT[Ch3]-vexRT[Ch1]*1.5; //right
		motor[port3] = vexRT[Ch3]-vexRT[Ch1]*1.5;
		motor[port8] = vexRT[Ch3]+vexRT[Ch1]*1.5;
		motor[port9] = vexRT[Ch3]+vexRT[Ch1]*1.5;
task shiftBase(){
	while(true){
	if(vexRT[Btn8R] == 1){
		clearTimer(T1);
		while(time1[T1] < 150){
		motor[port2] = -75;
		motor[port3] = -75;
		motor[port8] = 75;
		motor[port9] = 75;
	if(vexRT[Btn8L] == 1){
			clearTimer(T1);
		motor[port2] = 75;
		motor[port3] = 75;
		motor[port8] = -75;
		motor[port9] = -75;
	else if(time1[T1] >150){
		motor[port2] = 0;
		motor[port3] = 0;
		motor[port8] = 0;
		motor[port9] = 0;
task lift(){
	while(true){
		if(vexRT[Btn6U] == 1){
			motor[port4] = 127;
		if(vexRT[Btn6D] == 1){
			motor[port4] = -127;
		else if(vexRT[Btn6D] == 0 && vexRT[Btn6U] == 0){
			motor[port4] = 0;
task launchBallLeft(){
	int speed = 0;
	resetSensor(I2C_1);
	while(true){
		if(vexRT[Btn7U] == 1){
			speed = firstSpeed;
			motor[port5] = speed;
			motor[port6] = speed;
		if(vexRT[Btn7L] == 1){
			speed = secondSpeed;
		if(vexRT[Btn7R] == 1){
			speed = thirdSpeed;
			motor[port5] = 50;
			motor[port6] = 50;
		else if(vexRT[Btn7D] == 1){
			speed = 0;
task launchBallRight(){
	int speed = 0;
	setPIDforMotor(launch1,true);
	setPIDforMotor(launch2,true);
	while(true){
		if(vexRT[Btn8U] == 1){
			speed = firstSpeed;
		if(vexRT[Btn8D] == 1){
		else if(vexRT[Btn8D] == 0 && vexRT[Btn8U] == 0){
			speed = 0;
task grabControl(){
	while(true){
		if(vexRT[Btn5U] == 1){
			motor[port7] = -127;
		else if(vexRT[Btn5D] == 1){
			motor[port7] = 127;
		else if(vexRT[Btn5D] == 0 && vexRT[Btn5U] == 0){
			motor[port7] = 0;
task autoMode1(){
	clearTimer(timer1);
	while(true){
	motor[port5] = 80;
	motor[port6] = 80;
	motor[port7] = 0;
	if(time1[T1] == 3000){
		while(time1[T1]<=3500){
		clearTimer(timer1);
void pre_auton()
	// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
	// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
//                                 Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous(){
	if(SensorValue[mode1] == 0){
	startTask(autoMode1);
if(SensorValue[mode2] == 0){
	while(true){
		motor[port2] = 80;
		motor[port3] = 80;
		motor[port8] = 80;
		motor[port9] = 80;
//                                 User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
	setSpeed(99,94,50);
	while (true)
		V1 = getMotorVelocity(launch1);
		if(vexRT[Btn7U] == 1 || vexRT[Btn7L] == 1 || vexRT[Btn7R] == 1){
			startTask(launchBallLeft);
			stopTask(launchBallRight);
		else if(vexRT[Btn8U] == 1 || vexRT[Btn8D] == 1){
			stopTask(launchBallLeft);
			startTask(launchBallRight);
		startTask(baseControl);
		startTask(grabControl);
		startTask(lift);
		startTask(shiftBase);
A couple of issues to address in this code.
The main user control task is going to keep starting (and stopping) tasks, avoid doing that, here is a revised version that starts the persistent tasks once and checks to see of the launch tasks have been started or not before starting them.
task usercontrol()
  setSpeed(99,94,50);
  startTask(lift);
  while (true)
      if( getTaskState(launchBallLeft) == taskStateStopped ) {
      if( getTaskState(launchBallRight) == taskStateStopped ) {
Secondly, avoid reseting the encoder at the beginning of launchBallLeft, that will interfere with velocity control.
  int speed = 0;
  //resetSensor(I2C_1);
  while(true){
      speed = firstSpeed;
      speed = thirdSpeed;
      motor[port5] = 50;
      motor[port6] = 50;
      speed = 0;
I would also avoid mixing plain vanilla ROBOTC and natural language. These calls are probably unnecessary anyway, PID will be enabled for these motors by default as you set that in the motors&sensors setup dialog.
