How do I tune a pid program? This sounds like beginners luck but the loop works quite well with only the proportional component.
Also I added turnerror in the drive forward as well so that it drives straight but it doesn’t correct when i purposely nudge it off track.
Is there anything incorrect that you can see?
here is the code:
const double kp = 0.4;
const double ki = 0.0;
const double kd = 0.2;
//turn costants
const double tp = 0.5;
const double ti = 0.0005
//double proportion;
double totalError;
double rtotalError;
double integral;
double rintegral;
double integralActiveZone = 90;//adjust later
double integralPowerLimit = 50;//adjust later
double derivative;
double rderivative;
double leftPower;
double rightPower;
double terror; //turn error >:D
double gyroValue;
double gyroerror;
double turn_TotalError;
task gyroTask() //stolen from backwards crew :/
long rate;
long angle, lastAngle;
lastAngle=0.0;
gyroError=0.0;
// Change sensitivity, this allows the rate reading to be higher
setGyroSensitivity(gyro, gyroNormalSensitivity);
//Reset the gyro sensor to remove any previous data.
resetGyro(gyro);
wait1Msec(1000);
while (true) {
rate = getGyroRate(gyro);
angle = getGyroDegrees(gyro);
// If big rate then ignore gyro changes
if( abs( rate ) < 2 )
if( angle != lastAngle )
gyroError += lastAngle - angle;
lastAngle = angle;
gyroValue = angle + gyroError;
wait1Msec(10);
void Drive(double target) {
double error = target;
double lastError = target;
double rError = target;
double rLastError = target;
wait1Msec(20);
while(abs(error) > 3){
error = target - getMotorEncoder(left);
rError = target - getMotorEncoder(right);
if(error == 0){
break;
//left integral
if(abs(error) < integralActiveZone && error != 0){
totalError += error;
else totalError = 0.0;
if(totalError > integralPowerLimit){
totalError = integralPowerLimit;
if(totalError < -integralPowerLimit){
totalError = -integralPowerLimit;
integral = ki * totalError;
//right integral
if(abs(rError) < integralActiveZone && rError != 0){
rtotalError += rerror;
else rtotalError = 0.0;
if(rtotalError > integralPowerLimit){
rtotalError = integralPowerLimit;
if(rtotalError < -integralPowerLimit){
rtotalError = -integralPowerLimit;
rintegral = ki * rtotalError;
//derivative
derivative = kd * (error - lastError);
lastError = error;
rderivative = kd * (rerror - rlastError);
rlastError = rerror;
if(error == 0){
derivative = 0;
rderivative = 0;
//terror = turn error lol
terror = gyroValue*tp
LeftPower = 0.5 * (kp * error + integral + derivative);
RightPower = 0.5 * (kp * rError + rintegral + rderivative);
setMotorSpeed(Left,LeftPower+terror);
setMotorSpeed(Right,RightPower-terror);
wait1Msec(15);
StopMultipleMotors(Left,Right);
void PID_turn(heading,speed,diff){ //currently a PI loop. Might add D later
if (heading > 0){
while(terror<2){
terror = (heading - gyroValue)*tp;
if(abs(error) < diff/3 && error != 0){
turn_totalError += terror;
setMotorSpeed(left,-speed-(terror+ti*turn_totalerror));
setMotorSpeed(right,speed+terror+ti*turn_totalerror);
else if (heading < 0){
while(terror>-2){
setMotorSpeed(left,speed-(terror+ti*turn_totalerror));
setMotorSpeed(right,-speed+terror+ti*turn_totalerror);
wait1Msec(15);
stopMotor(left);
stopMotor(right);
