Hello.
I’ve been trying to code a PID auton for our robot but I’ve run into some bugs. Every time we set a value to desiredTurnValue the robot drives in two separate arcs. How can I change this to turn in place?
Here is the code:
/* Module: main.cpp */
/* Author: Connor */
/* Created: 3/15/2022 */
/* Description: PID Program */
#include "vex.h"
#include <cmath>
using namespace vex;
competition Competition;
void pre_auton(void) {
vexcodeInit();
//Settings
double kP = 0.1; //Proportional Gain (how fast the system responds)
double kI = 0.05; //Reset (repeats per amount of time)
double kD = 0.3; //Derivative (how far to predict change)
double turnkP = 0.1;
double turnkI = 0.01;
double turnkD = 0.1;
int maxTurnIntegral = 300; // These cap the integrals
int maxIntegral = 300;
int integralBound = 3; //If error is outside the bounds, then apply the integral. This is a buffer with +-integralBound degrees
//Autonomous Settings
int desiredValue = 200;
int desiredTurnValue = 0;
int error; //SensorValue - DesiredValue : Position
int prevError = 0; //Position 20 miliseconds ago
int derivative; // error - prevError : Speed
int totalError = 0; //totalError = totalError + error
int turnError; //SensorValue - DesiredValue : Position
int turnPrevError = 0; //Position 20 miliseconds ago
int turnDerivative; // error - prevError : Speed
int turnTotalError = 0; //totalError = totalError + error
bool resetDriveSensors = false;
//Variables modified for use
bool enableDrivePID = true;
//Pasted from a C++ resource
double signnum_c(double x) {
if (x > 0.0) return 1.0;
if (x < 0.0) return -1.0;
return x;
int drivePID(){
while(enableDrivePID){
if (resetDriveSensors) {
LeftBack.setPosition(0,degrees);
RightBack.setPosition(0,degrees);
//Get the position of both motors
int leftMotorPosition = LeftBack.position(degrees);
int rightMotorPosition = RightBack.position(degrees);
//Lateral movement PID
//Get average of the two motors
int averagePosition = (leftMotorPosition + rightMotorPosition)/2;
//Potential
error = averagePosition - desiredValue;
//Derivative
derivative = error - prevError;
//Integral
if(abs(error) < integralBound){
totalError+=error;
} else {
totalError = 0;
//totalError += error;
//This would cap the integral
totalError = abs(totalError) > maxIntegral ? signnum_c(totalError) * maxIntegral : totalError;
double lateralMotorPower = error * kP + derivative * kD + totalError * kI;
//Turning Movement PID
int turnDifference = leftMotorPosition - rightMotorPosition;
//Potential
turnError = turnDifference - desiredTurnValue;
//Derivative
turnDerivative = turnError - turnPrevError;
//Integral
turnTotalError+=turnError;
} else {
turnTotalError = 0;
//turnTotalError += turnError;
turnTotalError = abs(turnTotalError) > maxIntegral ? signnum_c(turnTotalError) * maxIntegral : turnTotalError;
double turnMotorPower = turnError * turnkP + turnDerivative * turnkD + turnTotalError * turnkI;
LeftDrive.spin(forward, -lateralMotorPower + (-turnMotorPower), voltageUnits::volt);
RightDrive.spin(forward, -lateralMotorPower + (turnMotorPower), voltageUnits::volt);
prevError = error;
turnPrevError = turnError;
vex::task::sleep(20);
return 1;
void autonomous(void) {
vex::task initpid(drivePID);
MainArm.setBrake(hold);
//Forward
resetDriveSensors = true;
desiredValue = 820;
BackClamp.open();
wait(.5,seconds);
//Grab
ArmClamp1.open();
ArmClamp2.open();
wait(2,seconds);
//Drive Back
desiredValue = -700;
wait(1,seconds);
//Release
ArmClamp1.close();
ArmClamp2.close();
desiredTurnValue = 450;
wait(1,seconds);
All.stop();
Drive.spin(fwd);
void usercontrol(void) {
enableDrivePID = false;
//Settings
double turnImportance = 0.5;
while (1) {
//Driver Control
double turnVal = Controller1.Axis1.position(percent);
double forwardVal = Controller1.Axis3.position(percent);
double turnVolts = turnVal * 0.12;
double forwardVolts = forwardVal * 0.12 * (1 - (std::abs(turnVolts)/12.0) * turnImportance);
//0 - 12 = -12
//0 + 12 = 12(due to cap)
LeftDrive.spin(forward, forwardVolts + turnVolts, voltageUnits::volt);
RightDrive.spin(forward, forwardVolts - turnVolts, voltageUnits::volt);
//Arm Control
bool topRightButton = Controller1.ButtonR1.pressing();
bool bottomRightButton = Controller1.ButtonR2.pressing();
if (topRightButton){
MainArm.spin(forward, 12.0, voltageUnits::volt);
else if (bottomRightButton){
MainArm.spin(forward, -12.0, voltageUnits::volt);
else{
MainArm.stop(brake);
//Intake Control
bool topLeftButton = Controller1.ButtonL1.pressing();
bool bottomLeftButton = Controller1.ButtonL2.pressing();
if (ArmDown.pressing() == 0){
RingConveyor.spin(forward, 12.0, voltageUnits::volt);
else if(topLeftButton){
else if (bottomLeftButton){
RingConveyor.spin(forward, -12.0, voltageUnits::volt);
else{
RingConveyor.spin(forward, 0, voltageUnits::volt);
//Front Clamp Control
if (Controller1.ButtonY.pressing()){
ArmClamp1.open();
ArmClamp2.open();
else if (Controller1.ButtonA.pressing()){
ArmClamp1.close();
ArmClamp2.close();
else{
wait(20, msec);
//Back Clamp Control
if (Controller1.ButtonUp.pressing()){
BackClamp.open();
else if (Controller1.ButtonDown.pressing()){
BackClamp.close();
else{
wait(20, msec);
//Platform
if(Controller1.ButtonB.pressing()){
RightBack.setBrake(hold);
RightFront.setBrake(hold);
RightMid.setBrake(hold);
LeftBack.setBrake(hold);
LeftFront.setBrake(hold);
LeftMid.setBrake(hold);
else if (Controller1.ButtonX.pressing()){
RightBack.setBrake(coast);
RightFront.setBrake(coast);
RightMid.setBrake(coast);
LeftBack.setBrake(coast);
LeftFront.setBrake(coast);
LeftMid.setBrake(coast);
wait(20, msec);
int main() {
pre_auton();
while (true) {
wait(100, msec);
