My PID will not work no matter what I do. I have tried to tune these two PID’s multiple times and I get the same result everytime. The driving PID will overshoot everytime by a lot. I have been able to make it less but it is just too much. It will overshoot by two feet. The turning PID is really weird though because even though its the exact same code as the driving PID it will barely move. My theory on it is that the velocity is somehow not high enough to even have the power to move the robot and I did test it by lifing the robot and it seems true. And yes I did try to change kp and kd and ki none of it works I am truly lost.
anyway here is the code
Drive_Gear_Ratio = (36/48)
max_speed = 100
min_speed = 50
error = 0
integral = 0
derivative = 0
previous_error = 0
kp = .5
ki = 0
kd = .01
kf = .3
kp2 = 500
ki2 = 0
kd2 = 0
kf2 = 500
def drive_distance(target_distance):
global error, integral, derivative, previous_error
# Reset PID variables
error = 0
integral = 0
derivative = 0
previous_error = 0
# Main PID loop
while True:
current_distance = ((3.14159265 * Wheel_Diameter) / 360) * (LeftDrive1111_motor_a.position(DEGREES)) * (Drive_Gear_Ratio)
error = target_distance - current_distance
integral = integral + error
derivative = error - previous_error
output = kp * error + ki * integral + kd * derivative
feedforward = kf * target_distance
speed = max(min_speed, min(max_speed, feedforward + max_speed - abs(output)))
left_speed = speed
right_speed = speed
if error < 0:
left_speed *= -1
right_speed *= -1
LeftDrive1111.set_velocity(left_speed, PERCENT)
LeftDrive1155.set_velocity(left_speed, PERCENT)
RightDrive1111.set_velocity(right_speed, PERCENT)
RightDrive1155.set_velocity(right_speed, PERCENT)
previous_error = error
wait(20, MSEC)
# Break the loop when close enough to the target
if abs(error) < 1:
LeftDrive1111_motor_a.set_velocity(0, PERCENT)
LeftDrive1155_motor_a.set_velocity(0, PERCENT)
RightDrive1111_motor_a.set_velocity(0, PERCENT)
RightDrive1155_motor_a.set_velocity(0, PERCENT)
break
def turn_to_angle(target_angle):
error = 0
integral = 0
derivative = 0
previous_error = 0
# Main PID loop for turning
while True:
current_angle = inertial_10.heading(DEGREES)
error = target_angle - current_angle
output = kp2 * error + ki2 * integral + kd2 * derivative
feedforward = kf2 * target_angle
left_speed = -1 * speed
right_speed = speed
LeftDrive1111_motor_a.set_velocity(left_speed, PERCENT)
LeftDrive1155_motor_a.set_velocity(left_speed, PERCENT)
RightDrive1111_motor_a.set_velocity(right_speed, PERCENT)
RightDrive1155_motor_a.set_velocity(right_speed, PERCENT)
# Update previous error
# Sleep for a short time to avoid excessive loop execution
wait(20, MSEC)
# Break the loop when close enough to the target angle
if abs(error) < 1:
break
