How to use a pillow block & securely attach a motor to a wheel through metal ?
please I need answers, for my robot that my team is building. ty
I asked the wrong thing I need answers to this How to use a pillow block & securely attach a motor to a wheel through metal
When to use a locking drive screw as opposed to a regular drive screw
I would recommend that you at least review (if not build) the V5 clawbot, to learn the basics of assembling vex components. The clawbot instructions are here: https://content.vexrobotics.com/docs/V5-Clawbot-BuildInstructions.pdf
Page 7 shows how motors are mounted to a bearing flat.
So last year I used this technique for my drive. It’s a great way to make a drive due to the little friction in pillow bearings. What you do is put the pillow bearings on the bottom of some C-channel and then mount the motor perpendicular to the C-channel where it lines up with the bearing. The motor will be looking over the side of the metal. I can post pictures if you need.
thanks much appriciated
thank u bro very appreciated
