Pistons locksets
We’re using wings with locksets, it worked pretty well however , when we extract pistons , the wing doesn’t stand still like it isn’t at 90 degrees
https://youtu.be/RruZ4rR-gUA?si=4M3kRP3iVA5e3yzT ( we’ve used approximatively the same prototype )
Do you mean “when we extend the air cylinders”?
We’ll need to see your bot, not the design you’re trying to copy…
Can you ask a specific question that you want help with?
I would try using the air flow valve fitting to slow it down, check your tubing make sure that its tightly connected or check the door hinges is one harder to open and close
(the door hinge) door hinge
I see what you mean now try moving the pistons closer or adding a stopper to the hinge (although my previous comment is still relevant for when one wouldn’t retract)
Yes definitely , one of the hinges doesn’t close and open as easily as the other
And i actually tried to move the cylinders , add spacers but like that’s not really the problem because both the wings don’t stand still or if we move the cylinders when we open the wings they don’t open 90 degrees
