Okay, so here is the question: What is the competition most likely going to be next season? Okay so you can’t answer the question for sure, but you can make some likely guesses. First some data…
2016 - 2017…12’ x 12’ field, stars and cubes, separated robots, not team specific scoring objects, throw objects over fence, objects can be descored…Starstruck
2015 - 2016…12’ x 12’ field, balls, not separated robots, team specific scoring objects, balls in net, objects can not be descored…Nothing But Net
2014 - 2015…12’ x 12’ field, cubes, not separated robots, team specific scoring objects, cubes on poles, objects can be descored…Skyrise
2013 - 2014…12’ x 12’ field, balls and smaller balls, not separated robots, team specific objects, objects in specific locations, objects can be descored…Toss Up
2012 - 2013…12’ x 12’ field, sacks, not separated robots, not team specific scoring objects, place objects on goals, objects can be descored…Sack Attack
2011 - 2012…12’ x 12’ field, balls and barrels, not separated robots, team specific scoring objects, score balls and barrels in corners or in circular goals, objects can not be descored…Gateway
Of course the field will still be 12’ x 12’ and autonomous and user control will stay the same. The first patter I notice is the alternation of using balls and not. 2011 - 2012 there are ball, the next there aren’t, the next there are, etc. This means there is a likely chance that next season we will see some sort of balls as game objects. Also over the years they seem to use team specific objects more than none team specific objects; most likely then, team specific objects will be used. Driving around the field will of course still be necessary no matter what the challenge is…
So what do you think?
