Plastic field straps source or alternatives?
Hi, need to set up an event soon but the plastic fields we’re borrowing are missing the straps that keep the walls from coming apart.
Any ideas where to get those from or the closest replacement? Tried a generic ratchet strap I had in the garage but have to devise some sort of something for the ends, doesn’t work as is and is not as plug and play as the original velcro one from VEX. Also don’t have the fields on hand to test things.
Was thinking others went through this and came up with some clever solution (other than placing weights and/or buckets of sand LOL)?
Thanks.
If you email [email protected] they can generate an invoice for you to purchase new straps.
Contact [email protected] and they can give you some replacement straps.
In a pinch, we have fastened the field walls to the floor using gaffers tape. (We get our gaffer’s tape by the carton from tapejungle.com and they offer a discount if you don’t care what color you get).
