/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Controller1 controller
// Drivetrain drivetrain 1, 11, 14, 2
// Motor18 motor 18
// Motor19 motor 19
// BumperB bumper B
// LightC light C
#include "vex.h"
using namespace vex;
competition Competition;
controller Controller1 = controller(primary);
motor leftfront = motor(PORT1, ratio18_1, false);
motor leftback = motor(PORT11, ratio18_1, false);
motor_group LeftDriveSmart = motor_group(leftfront, leftback);
motor rightfront = motor(PORT14, ratio18_1, true);
motor rightback = motor(PORT2, ratio18_1, true);
motor_group RightDriveSmart = motor_group(rightfront, rightback);
drivetrain Drive = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 295, 40, mm, 1);
motor Motor18 = motor(PORT18, ratio18_1, false);
motor Motor19 = motor(PORT19, ratio18_1, false);
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
/* set velocity */
leftfront.setVelocity(80, percent);
leftback.setVelocity(80, percent);
rightfront.setVelocity(80, percent);
rightback.setVelocity(80, percent);
/*forward*/
leftfront.startRotateFor(vex::directionType::fwd, 100, vex::rotationUnits::deg);
leftback.startRotateFor(vex::directionType::fwd, 100, vex::rotationUnits::deg);
rightfront.startRotateFor(vex::directionType::fwd, 100, vex::rotationUnits::deg);
rightback.rotateFor(vex::directionType::fwd, 100, vex::rotationUnits::deg);
/*pick up*/
/*turn left and right*/
leftfront.startRotateFor(vex::directionType::rev, 90, vex::rotationUnits::deg);
leftback.startRotateFor(vex::directionType::rev, 90, vex::rotationUnits::deg);
rightfront.startRotateFor(vex::directionType::fwd, 90, vex::rotationUnits::deg);
rightback.rotateFor(vex::directionType::fwd, 90, vex::rotationUnits::deg);
/*forward and reverse*/
leftfront.startRotateFor(vex::directionType::rev, 100, vex::rotationUnits::deg);
leftback.startRotateFor(vex::directionType::rev, 100, vex::rotationUnits::deg);
rightfront.startRotateFor(vex::directionType::rev, 100, vex::rotationUnits::deg);
rightback.rotateFor(vex::directionType::rev, 100, vex::rotationUnits::deg);
vex::motor(leftfront).stop();
vex::motor(leftback).stop();
vex::motor(rightfront).stop();
vex::motor(rightback).stop();
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1) {
motor_group(LeftDriveSmart).spin(forward, Controller1.Axis3.position() + Controller1.Axis4.position() / 4, pct);
motor_group(RightDriveSmart).spin(forward, Controller1.Axis3.position() - Controller1.Axis4.position() / 4, pct);
//control arm with R1 and R2 buttons
if(Controller1.ButtonR1.pressing()) {
Motor18.spin(vex::directionType::fwd, 100,vex::velocityUnits::pct);
else if(Controller1.ButtonR2.pressing()) {
Motor18.spin(vex::directionType::rev, 100,vex::velocityUnits::pct);
else {
Motor18.stop(vex::brakeType::brake);
// control claw with L1 and L2 buttons
if(Controller1.ButtonL1.pressing()) {
Motor19.spin(vex::directionType::fwd, 100,vex::velocityUnits::pct);
else if(Controller1.ButtonL2.pressing()) {
Motor19.spin(vex::directionType::rev, 100,vex::velocityUnits::pct);
else {
wait(20, msec); // Sleep the task for a short amount of time
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
edit: code tags added by mods.
