I was just wondering how many actuations you can get out of one air tank? This is assuming that I will be using low air pressure to maximize the amount of actuations that you can get.
It depends on if you are using single or double acting pistons, how many psi in your tank, etc. I got a solid 80 actuations when i had 100 psi in two tanks and used one double acting piston as a single acting piston and had the solenoid close to the piston.
