Pneumatic capacity
how do we extend the amount of actuation we can get out of our two tanks? we can currently get around 25 before it gets weak
Reduce the length of tubing from solonoid to piston, can i ask what the pistons are used for?
Give the piatons more leverage on the claw and ise a valve (black) to use the least amount of air possible before it stops working altogether.
To be honest, the pneumatic claws use a ton of PSI just for one blow. In my opinion, it would be best to have each claw have their own reservoir so the connections would be closer and it would be WAY more reliable because it’s not separating by a T-Splitter(Or however you call it). One thing I recommend is seeing if the black resistors(Or whatever you call it) and see if you can use anything from them. With me they resisted too much, but luckily by making the claws have their own reservoirs made them last much longer than supposed to.
