I’ve watched a decent bit of videos and in all of them the teams using pneumatics can uses them multiple times, even with the 100 Psi limit, when my team tries to use pneumatics we get two good uses out of them before running out of air, just to clarify we are trying to use pistons.
A properly built pneumatic system will give you 15-30 or more actuations of your air cylinders (the proper term for what you’re calling “pistons”). I suggest you read this article: https://kb.vex.com/hc/en-us/sections/4404197392404-Pneumatics and try rebuilding your system to see if you can get it working properly.
