Pneumatics affecting motor performance
Hi! I just started using pneumatics and I feel like it is draining the battery power faster and affecting the performance of my motors on the bot. Any ideas on how to make sure pneumatics doesn’t change anything?
its just because the brains power out put is not high enough to keep them all running at top speed at the same time
Sure it is, unless the battery has issues.
We had the same issue with the pneumatics draining battery. My team coded a button on the controller to turn off and on pneumatics, so when we’re not using them during the match, it doesn’t waste battery. I don’t know how necessary your pneumatics are for this robot so it might waste time.
Thank you! I’ll try that :slight_smile:
