Pneumatics extension
Hy guys , so herés a little problem i need a quick solution for( pleaseeeeee!!!)
So we ´ ve just recently done the pneumatics for the catapult system and it worked well however there is a problem it’s that it doesn’t score in the highest target
And we truly need that :pray::pray::pray:
Can we please get some photos? I don’t exactly know by what you mean by pneumatic system.
Please provide pictures. All we currently know is that your catapult isn’t powerful enough to score in the higher target. Pictures will let us find the actual issue with the catapult which is causing it to underperform.
pneumatics are not powerful enough by themselves to shoot a catapult. Try using rubber bands instead.
If you plan to use the pneumatic kit only for scoring, it may only work for low scoring. The pneumatic kit will not give you enough power to launch the balls to high areas. You should look into the Choo Choo Mechanism and use some rubber bands to tension the catapult for launching.
There is actually a rubber band however when we try to increase the tension the pneumatics are not powerful enough to launch and retract back they only launch once and not even in the high target
Can adding a motor be a solution ?? Or maybe another kit if pneumatics ??
