Pneumatics fire when I stop a program
I have a pneumatic transmission on my robot and I have it set so the default setting is in high gear. If I have the brain powered off it is in high gear, if I turn the brain on it is also in high gear, but then if I open and close a program it will switch into low gear. This is really annoying especially when resetting for autonomous. Closing a program seems to change the default position of the solenoids so is there anyway I can fix this?
Is VEXcode vexos fully updated to 1.1.1 ?
Pneumatics should be in the same state when a program is stopped as when the brain is first powered, that was a change in 1.1.1.
I did have 1.1.1 installed so I factory reset the brain and installed it again and it worked
