Pneumatics HELP Mogo clamp
Hello! This is my first time using pneumatics, I am trying to make a mogo clamp but don’t know what I’m doing. Can someone give me a starting point and what size cylinders I would need for that idea?
Look up “high stakes mogo clamp” or “Tipping piint mogo clamp” and you should get a few ideas:
https://youtu.be/ktCnJYVn7jY?si=ZCJWK6h_RrpiVesN
https://youtu.be/gyrjW_vPuQ8?si=kkivA2mDtvfsXXSR
https://youtu.be/1auxsSvdaiE?si=HoYlwskyCSZrSVtK
https://youtu.be/tVmx98TXer8?feature=shared
https://youtu.be/YkzFfF5XOf0?si=tXQ83MZryFDRZBJy
The shorter the piston stroke, the better (25mm for VEX ones). They use less air per actuation, and hence can be fired more times.
Thank you! For the info
