So far I’ve managed to find all the parts in the single acting pneumatic kit except for three, the tire pump fitting and the two cylinder mounts. Anybody know where I can find them?
I can’t help you with the three your missing, but where did you find all the other parts? From this post?
no i searched the part numbers on the plc center. i can post the links if you want
This is a similar valve to the one currently used in the VEX Pneumatics System.
http://www.plccenter.co.uk/en-US/Buy/SMC/US3729
You should be able to work your way around the mounts, and use a different method for attaching the cylinders.
Hope this helps.
Thanks.
-Eli
The mounts aren’t sold (I believe) those are made by VEX? Correct me if I’m wrong.
I just custom made some mounts out of lexan or plastics. They work great if done right.
- Andrew
That is correct Andrew, custom made by VEX.
Is possible to build a similar mount out of VEX structure, like using parts of a flexible 1x25 Bar.
Using Lexan to build the mounts is also a good idea.
-Eli
Lucky colleges get plastic because the rest of us dont want to waste our precious lexan
Why not offer them as a seperate part? I know there are business reasons but I think it would be quite awesome if this were to be done.
If you do it right you shouldn’t need one or you can make one very small mount. I guess it depends mainly on the mechanism.
What I’m doing is drilling the hole to .25 and using standoff to mount them.
- Andrew
Could you please post the results of your search? You will save many of us a bit of time! Thank you!
I found the bike valve at o’riley’s autobparts but I’m sure u could find it at any generic auto parts store
