I have issues with the wires that connects pnumatics with the cortex.
“Solenoid Driver - Cable w/Driver, Connects one VEX I/O Port to one Solenoid - SOLENOID-DRIVER”
I tried everything and cannot seem to fix the wires. I checked the wires and they are all fine with no cuts or anything.
Recently our school bought new pnumatics set and when I tried these wires, the pnumatics worked just fine.
I don’t know whats the problem with old wires.
I need two wires for 2 pistons.
If anyone has extra ones that they can lend me at worlds will be great. Also if you have any suggestions for me, please help…
Thanks:confused:
Whenever I use my old wires, my pneumatic wings don’t pop out. If I use the new wire it pops out. I switched the cortex, ports pistons and everything. Still same problem. I will have another look tommorow.
If they don’t work I am screwed for worlds:confused:
Hope for best:)
Check the obvious things, are they plugged in the correct way around, black on the outside of the cortex. I assume they are if you tried a working replacement, anyway VEX does sell the cables as an individual part.
I don’t know if you switched ports when you got the new pneumatics. But maybe the port you had the wire plugged in the first time could be faulty. If you tried a different port already with it and it still doesn’t work I have no idea. Make sure its in the right section on the cortex too on the digital side.
