Pneumatics
We just found some pneumatics which havent been used ever.
What are the pros and cons of pnematics?
How reliable are they?
Congrats on your new lost then found!
Pros:
Very reliable
Powerful
Repeatable action
Versatile
Cons:
Expense
Bulky
Heavy
More wires and tubing
Yes they are very reliable when properly installed, more reliable than motors in my opinion even though they are apples to oranges.
Thank you for that!
I did have one more question, lets say we a cube intake that is only 12 inches long, we make a part that when you press a button the pneumatics forces the second intake down, making it longer. Will the intake we pushed down stay down, or will it go back up after we stop pressing the button?
Depends on how you program them to work.
This will make it toggle:
if(vexRT[Btn5U] == 1)
    SensorValue[piston] = 1;
else if(vexRT[Btn5D] == 1)
    SensorValue[piston] = 0;
If you want it to release as soon as it is not pressed, it will have to be programmed like this:
else
That helps alot, thanks!
The code above requires that you use two buttons,
If you hope to use only 1 Button to toggle, that is possible too,
if(vexRT[Btn5U] == 1&&SensorValue[piston] == 0) // Checks for Up Pressed and pneumatics in
    SensorValue[piston] = 1; // Sets Pneumatics to out
    while(vexRT[Btn5U] == 1) // wait for release of button to continue
             wait1Msec(10);
else if(vexRT[Btn5U] == 1) // Checks for Up Pressed
    SensorValue[piston] = 0; // Sets Pneumatics to in
             wait1Msec(10);
Thanks! we were planning on one button anyways.
It also depends on whether you’re using double-acting or single-acting pistons. The double-acting ones will stay down, but the single acting ones automatically retract.
We only have a single tank.
