Out of the box I hooked up the two motors to the brick. One in port 1 and the other in port 6. Like it shows in the manual, a few steps before the clawbot is complete. I opened the default set up with the driver control and ran it. I noticed that port 6 was not responding. It was not the motor’s fault because any motor plugged into port 1 would work, but not when plugged into port 6.
I decided to upgrade all parts to the latest firmware, but now the problem has switched. Port 6 now works, but port 1 doesn’t. I haven’t been able to find a solution out of the manual or on the forum.
We believe this is being caused by a setting under your “Configure” menu, please confirm with option you have selected under the *Control *of the Configure menu.
In order to access the *Configure *menu please follow this steps: Power on IQ Brain> select Driver Control> Select Configure
I’ve experienced this before that when you plug in the two other motors for the claw bot it activates the ones in port 1 and 6, and at this moment they to stay that way even when you unplug the ones in port 10 and 11. But now the problem I’m having is when I push both joysticks forwards the robot goes back. Under the configure menu i have: Control: 2 Joystick Drive: Normal Motor 4,5,10,11:Normal Switching drive to reverse only help to drive straight forward but the turns are reversed
