Port 4 is the only port working any suggestions?
#pragma config(Motor, port1, armMotor, tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port2, frontRight, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port3, backRight, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, frontLeft, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port5, backLeft, tmotorVex393_MC29, openLoop, reversed, encoderPort, None)
#pragma config(Motor, port6, beltMotor, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, rotationMotor, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, clawMotor, tmotorVex393_MC29, openLoop, encoderPort, None)
/*+++++++++++++++++++++++++++++++++++++++++++++| Notes |++++++++++++++++++++++++++++++++++++++++++++
  • The left joystick Y-axis controls the robot’s forward and backward movement.
  • The left joystick X-axis controls the robot’s left and right movement.
  • The right joystick X-axis controls the robot’s rotation.
  • The Code incorportes a threshold/deadzone that allows very low Joystick values to be ignored.
    This allows the robot to ignore values from the Joysticks when they fail to center at 0,
    and provides a margin of error for the driver when they only want the robot to move in one axis.
[I/O Port] [Name] [Type] [Description]
Motor Port 2 frontRight VEX Motor Front Right motor
Motor Port 3 backRight VEX Motor Back Right motor
Motor Port 4 frontLeft VEX Motor Front Left motor
Motor Port 5 backLeft VEX Motor Back Left motor
task main()
//Loop Forever
while(1 == 1)
//Remote Control Commands
motor[frontRight] = vexRT[Ch3] - vexRT[Ch1] - vexRT[Ch4];
motor[backRight] = vexRT[Ch3] - vexRT[Ch1] + vexRT[Ch4];
motor[frontLeft] = vexRT[Ch3] + vexRT[Ch1] + vexRT[Ch4];
motor[backLeft] = vexRT[Ch3] + vexRT[Ch1] - vexRT[Ch4];
////________________________________________________________________________________________________________
//above is the code for the wheels which allows wheels to move in a 350 degrees rotation.
if(vexRT[Btn7U] == 1)       	//If button 7U is pressed...
	motor[armMotor] = 127;    	//...raise the arm.
else if(vexRT[Btn7D] == 1)  	//Else, if button 7D is pressed...
	motor[armMotor] = -127;   	//...lower the arm.
else                      		//Else (neither button is pressed)...
	motor[armMotor] = 0;      	//...stop the arm.
//////______________________________________________________________________________________________________
//above is the code for the arm which allows it to move up and down
// Open, close or do not more claw
if(vexRT[Btn6U] == 1)       	//If Button 6U is pressed...
	motor[clawMotor] = 127;  		//...close the gripper.
else if(vexRT[Btn6D] == 1)  	//Else, if button 6D is pressed...
	motor[clawMotor] = -127; 		//...open the gripper.
	motor[clawMotor] = 0;    		//...stop the gripper.
////_______________________________________________________________________________________________________________
//above is the code for the claw allowing it to open and close
if(vexRT[Btn7L] ==1)			//If button 7L is pressed
	motor[beltMotor] = 127;  		//Move the Conveyor belt forward
else if(vexRT[Btn7R] == 1)  	//Else, if button 7R is pressed...
	motor[beltMotor] = -127; 		//Move the Conveyer belt backwards.
	motor[beltMotor] = 0;    		//...stop the Belt.
//above is the code for the conveyor belt allowing it to move back and forth
if(vexRT[Btn8R] ==1)			//If button 8R is pressed
	motor[rotationMotor] = 63;  		//Rotates the claw
else if(vexRT[Btn8L] == 1)  	//Else, if button 8L is pressed...
	motor[rotationMotor] = -63; 		//Move the Conveyer belt backwards.
	motor[rotationMotor] = 0;    		//Dont rotate
Nvm fixed sorry for any time wasted
Don’t leave us hanging @MagicLizard01, tell us what the fix was so we can all learn!
The wires i was using were faulty
