Quick question that I can’t seem to find a simple answer online. Since port 1 and 10 on the cortex are 2 point connectors, does this mean that these two ports have motor controllers built in?
Yes, you do not need to wire a motor controller with this, you simply plug the motor into the port.
the cortex has 2 internal motor controllers that work the same as plugging one into a 3 wire port
