Hi. I was looking through the manual and Appendix A for Tipping Point and I couldn’t find a limit on how many rings a robot can possess at one time. Is there a limit and what is it?
Thank you
There is no ring possession limit. A general rule is, if it doesn’t say you can’t, you can do it. Just remember rule G3, common sense.
On the not of ring possession, I don’t see much of a reason to hold more than 10 as that is enough to fill a ring. Hoarding rings also won’t be viable, because the other alliance has 15 rings worth of preloads/match loads.
