The potentiometer output was from 1 - 1024. After we updated our EasyC4 software to version 4.0.2.7, it was found that the output was from 1-85.
Is it right or we did something wrong?
Thanks
Thanks
I’d double check the POT with the online window. There were no changes to the code that would cause the issue you are seeing. Also, make sure the firmware is current on the Cortex.
Also, make sure your cortex controller is ON with a charged battery conncted.
I found out I made mistake because I forgot to turn on the robot.
