We tried to add a motor hold to our chain arm so when its on either side. At the end of the code in comments is what we tried but we do not know where to put it if it will even work. Any Suggestions???
#pragma config(Sensor, in1, GyroBoi, sensorGyro)
#pragma config(Sensor, in2, SmokePot, sensorPotentiometer)
#pragma config(Sensor, dgtl1, sensorleft, sensorQuadEncoder)
#pragma config(Sensor, dgtl3, sensorright, sensorQuadEncoder)
#pragma config(Sensor, dgtl5, solenoid, sensorDigitalOut)
#pragma config(Sensor, dgtl6, SWERVEBOT, sensorLEDtoVCC)
#pragma config(Motor, port2, FrontRight, tmotorVex393HighSpeed_MC29, openLoop, reversed, encoderPort, dgtl3)
#pragma config(Motor, port3, FrontLeft, tmotorVex393HighSpeed_MC29, openLoop, encoderPort, dgtl1)
#pragma config(Motor, port4, Lifty, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port5, wyattsucks, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, claw, tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor, port7, Mobilee, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, BackRight, tmotorVex393HighSpeed_MC29, openLoop, reversed, encoderPort, dgtl3)
#pragma config(Motor, port10, BackLeft, tmotorVex393_HBridge, openLoop, encoderPort, dgtl1)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
// This code is for the VEX cortex platform
#pragma platform(VEX2)
// Select Download method as "competition"
//Main competition background code...do not modify!
#include "Vex_Competition_Includes.c"
void Drive(int distance, int power)
SensorValue[sensorleft] = 0;
SensorValue[sensorright] = 0;
while((distance > 0 && SensorValue[sensorleft] < distance)||( distance < 0 && SensorValue[sensorleft] > distance))
if(SensorValue[sensorright] > SensorValue[sensorleft])
motor[FrontLeft] = power;
motor[BackLeft] = power;
motor[FrontRight] = power * (8.0/10);
motor[BackRight] = power * (8.0/10);
else if(SensorValue[sensorright] < SensorValue[sensorleft])
motor[FrontLeft] = power * (9.0/10);
motor[BackLeft] = power * (9.0/10);
motor[FrontRight] = power;
motor[BackRight] = power;
else if (SensorValue[sensorright] == SensorValue[sensorleft])
motor[FrontLeft] = 0;
motor[BackLeft] = 0;
motor[FrontRight] = 0;
motor[BackRight] = 0;
void turnLeft (int angle, int power)
while((angle > 0 && (SensorValue[sensorright] > -angle || SensorValue[sensorleft] > -angle))
|| ((angle < 0) && (SensorValue[sensorright] < -angle || SensorValue[sensorleft] < -angle)))
motor[BackLeft] = -power;
motor[FrontLeft] = -power;
void mobile (int time, int power)
motor[Mobilee] = power*1;
wait1Msec(time);
motor[Mobilee] = 0;
void pre_auton()
task autonomous()
AutonomousCodePlaceholderForTesting();
task usercontrol()
while (true)
motor[FrontLeft] = vexRT[Ch3];
motor[BackLeft] = vexRT[Ch3];
motor[FrontRight] = vexRT[Ch2];
motor[BackRight] = vexRT[Ch2];
if (vexRT(Btn7U)==1)
motor[Lifty] = -120;
else if (vexRT(Btn7D)==1)
motor[Lifty] = 120;
else
motor[Lifty] = -20;
if (vexRT(Btn5U)==1)
motor[Mobilee] = 120;
else if (vexRT(Btn5D)==1)
motor[Mobilee] = -100;
else
motor[Mobilee] = 10;
if(vexRT(Btn6U) == 1)
SensorValue[solenoid] = 1;
else
SensorValue[solenoid] = 0;
if (vexRT(Btn8U)==1)
motor[claw] = 120;
else if (vexRT(Btn8D)==1)
motor[claw] = -120;
else
motor[claw] = 5;
while(SensorValue[SmokePot] > position)
motor[FrontLeft] = 20;
motor[BackLeft] = 20;
motor[FrontRight] = 20;
motor[BackRight] = 20;
while(SensorValue[SmokePot] < position)
motor[FrontLeft] = -20;
motor[BackLeft] = -20;
motor[FrontRight] = -20;
motor[BackRight] = -20;
