So I decided to try using an LCD to output the main and power expander voltage. I just used the sample program and put it where it should go, changing “backupBattery” to “powexpBattery”
task usercontrol()
string mainBattery, powexpBattery;
while(true) // An infinite loop to keep the program running until you terminate it
clearLCDLine(0); // Clear line 1 (0) of the LCD
clearLCDLine(1); // Clear line 2 (1) of the LCD
//Display the Primary Robot battery voltage
displayLCDString(0, 0, "Primary: ");
sprintf(mainBattery, "%1.2f%c", nImmediateBatteryLevel/1000.0,'V'); //Build the value to be displayed
displayNextLCDString(mainBattery);
//Display the Backup battery voltage
displayLCDString(1, 0, "PowerExp: ");
sprintf(powexpBattery, "%1.2f%c", SensorValue(status)/70, 'V'); //Build the value to be displayed
displayNextLCDString(powexpBattery);
//Short delay for the LCD refresh rate
wait1Msec(500);
I connected the controller and it ouputed “32.9V”, so I added another zero to the bolded 70 (70 was the divisor on the pdf from vex). It now outputed “3.29V” I tested the voltage manually, and it was about 8. Using just the raw input from the analog port I was using, i found it was outputting 2000 instead of something reasonable like 400-600ish. Why is this happening? The file is below. It doesn’t allow .c files, so it is just a text file.
Edit: I should add that the main voltage works fine
