Power Expander
Can someone help me. We are using a power expander and trying to display the voltage of the power expander on the lcd. We created the code but the lcd is given us a battery reading of 27volts. any idea why???
here is the code (using RobotC)
{//Open LCD battery loop
			bLCDBacklight = true;					// Turn on LCD Backlight
			string mainBattery, backupBattery;
				clearLCDLine(0);						// Clear line 1 (0) of the LCD
				clearLCDLine(1);						// Clear line 2 (1) of the LCD
				//Display the Primary Robot battery voltage
				displayLCDString(0, 0, "Primary: ");
				sprintf(mainBattery, "%1.2f%c", nImmediateBatteryLevel/1000.0,'V'); //Build the value to be displayed
				displayNextLCDString(mainBattery);
				//Display the Power Expander battery voltage
				displayLCDString(1,0, "Secondary:" ) ;
				sprintf(backupBattery, "%1.2f%c", (((float)SensorValue[in1] * 5.48 / 184.7)), 'V');
				displayNextLCDString(backupBattery);
				//Short delay for the LCD refresh rate
				wait1Msec(100);
		}//Close LCD battery loop
Where did the 5.48 come from, the two division factors on the wiki are 280 or 182.
SensorValue[in1] / 280.0
Not entirely sure where 5.48 came from. A team member found a post online which had it in there so i thought i would give it a shot.
Actually, it was sort of a rhetorical question, it was probably one of my posts.
To convert raw sensor value to volts you divide by either 280 (new power expander) or 182 (old power expander).
To convert raw sensor data to mV (mV = 1/1000 volt) you multiply by 1000/280 = 3.57 (new power expander) or by 1000/182 = 5.49 (old power expander).
So it all depends if you want to convert to volts or mV and whether you have one of the new (revision A2 or newer, it’s printed on the power expander somewhere) or the old power expanders.
So i have tried a few different numbers from the wiki (280, 182, 70.8, 45.6, 155, 70) all of this values have not worked for me. We are getting a analog reading of 538, with a battery with 8.4v. Any suggestions on way its not working??? I am puzzled by this…:confused::confused::confused::confused:
Strange, which version of ROBOTC are you using?
What is the value if you disconnect the cable (ie. nothing connected to in1 ) ?
I am using version 3.65 (most up to date). When nothing is plugged in we get a reading of 0. In addition we tried other analog ports with similar readings to 538 with the 8.4v battery.
Hmm, another question based on those remarks. Any chance you are using a PIC? We all assumed you have a cortex but if you have a PIC then I understand what’s happening.
Nope we are using the vex Cortex.
