Power Expander
We just bought a power expander and i have no idea how to use it can you give me a dummy explanation from where you plus things into to programming it thanks alot
Here is the vex instruction sheet.
thanks what do you plus in the status port
plug
Plug it into an analog port and set it up as an analog sensor.
PS: you can use the edit button on the vex forum to change mistakes in typing.
what do you mean by plug it into an analog port?
Take a 3-wire extension cable. Plug one end into a port on the cortex labeled “analog.” Plug the other end into the port labeled “status” on the power expander. Use more 3-wire extension cables if you need the power expander to be farther from the cortex and just one won’t reach far enough.
