Pre Match Auton
How do you deal with pre match autonomouses for different sides of the field and dofferent colours etc. Do you have seperate scripts or some kind of input pre match to set it?
You could do either. Most teams simply have multiple slots for different programs, but if you wanted to combine them together so you only run off of one slot on the controller, and select which program on your brain/controller (or even use a potentiometer), this would work as well. There are many topics on the forum already about autonomous selectors, if this is the route you decide to take.
Just found some brilliant other threads, sorry for wasting your time i should have searched first
