Since many people have burned out motors by putting too much torque on them, and the motors are expensive, I wrote a code that acts like a circuit breaker when too much torque is applied. It will temporarily stop the motor until the user presses a button to release it. All you need is an encoder. I have only written it for one motor, and because every robot is different, you will have to add more code to make it work for multiple motors. You can change the amount of torque that is needed before the motors stops by changing the value of the variable “threshold”. Here is the code:
#pragma config(Sensor, dgtl1, quad, sensorQuadEncoder)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task clutch(){
int quadPrev = 0; //stores previous encoder value
float threshold = .01; //variable to increase or decrease the torque at which the motor stops.
SensorValue(quad) = 0; //reset encoder
wait1Msec(100); //initialize
while(true){
if(motor[port2] > 20 || motor[port2] < -20){ //checks if motor is running at a reasonable speed
wait1Msec(100); //checks for stop and go movement
while(motor[port2] > 20 || motor[port2] < -20){
quadPrev = SensorValue(quad); //set quadPrev equal to the current encoder value
wait1Msec(100);//let the motor run a little
if(abs(quadPrev - SensorValue(quad)) < (abs(motor[port2]) * threshold)){
//IMPORTANT PART: checks if the axle has moved the correct amount in proportion to the motor speed
motor[port2] = 0; // stops motor
hogCPU(); //stops task main from executing until the release button is pressed
while(!vexRT[Btn6U]){ //this button releases the motor
motor[port2] = 0; //stops the motor which is not running correctly
//insert all user controls except for the motor that is being stopped
releaseCPU(); //starts running task main again
task main(){
StartTask(clutch);
while(true){
motor[port2] = vexRT[Ch1];
wait1Msec(1);//needed for multitasking to work correctly
That’s it. If you implement this, let me know how it goes.
