Printing code from VCS
Do you guys know if there is a way to print code from Vex Coding Studio. I know there is a print button in the drop down next to the program name but i’m not able to select it. Is there something I have to do to fix that or is there currently no way to print code directly from VCS? And if there is no way to print code directly from VCS whats the easiest way you guys have found to do it?
Copy and Paste your code into some other editor like Sublime or Atom and use their print feature.
You could also find some sort of online syntax highlighter printer.
also highlight and right click and see if you can print
