So i have the following:
while (true) {
Brain.Screen.printAt(0, 20, "Battery Capacity %d percent", Brain.Battery.capacity());
Brain.Screen.printAt(0, 40, "Battery Temperature %lf", Brain.Battery.temperature());
Brain.Screen.printAt(0, 60 ,"Letft Back Temp %f " , left_back.temperature(percentUnits::pct));
Brain.Screen.printAt(0, 80 ,"Left Front Temp %f " , left_front.temperature(percentUnits::pct));
Brain.Screen.printAt(0, 100 ,"Right Front Temp %f " , right_front.temperature(percentUnits::pct));
Brain.Screen.printAt(0, 120 ,"Right Back Temp %f " , right_back.temperature(percentUnits::pct));
Brain.Screen.printAt(0, 140 ,"Lift Left Temp %f " , lift_left.temperature(percentUnits::pct));
Brain.Screen.printAt(0, 160 ,"Lift Right Temp %f " , lift_right.temperature(percentUnits::pct));
Brain.Screen.printAt(0, 180 ,"Hook Temp %f " , hook.temperature(percentUnits::pct)); }
How would I get the brain to update the values every 5 seconds? Also, how would I have the brain change the font color of the text depending on if the temp is higher than a certain degree?
