So to test my functions i use the print() statement and to print to the cmd i have to have the laptop connected to the robot at all times, but my computers ports and the brains ports are a little weird, the connection to the port is easily broken. So with little movement of the bot, the port easily disconnects and i cant read the values on the laptop screen until i restart the program.
So i wondering if you guys have any suggestions as to what i could do, or what you guys do to get values while the robot is moving?
The brain supports and sd card so you can make a text file and write the data to it. Generate a random number or something so it doesn’t always overwrite the same file.
The main branch (the one that releases are built off of) of the CLI does not support wireless debug. However the branch feature/wireless-terminal does. You’ll need to clone that branch and install the CLI manually to get wireless debug working. Keep in mind that it is still in an experimental state and is not as polished or stable as PROS typically is.
