Printing to the brain
Hello,
I was curios on how to fix the following issues:
  1. Text when printing to the brain screen is too small. Is there a way to make the text bigger when printing on the screen?
  2. Text on the screen is pretty annoying to read. Is there a way to highlight that text and make it easier to read?
Thanks.
Basically you just set the font and the size is the number.
Brain.Screen.setFont(FONT);
description from Vexcodev5
Brain Screen Set Font
Sets the style and size of font used on the V5 Brain’s screen when printing numbers or text.
Brain.Screen.setFont(monoM);
How To Use
There are two different types of fonts available on the V5 Brain’s screen:
  • Monospaced (Mono) - each character takes up the same width.
  • Proportional (Prop) - each character takes up different size widths based on the character.
Choose which font type and size to use. You can select from the following font options.
  • mono12
  • mono15
  • mono20
  • mono30
  • mono40
  • mono60
  • prop20
  • prop30
  • prop40
  • prop60
The new font size will be used for any future text written to the V5 Brain’s screen.
Thanks so much!
Would you happen to know if there is a feature for highlighting text that is printed to the brain?
You can use Brain.Screen.setFillColor(); to set the highlight color and Brain.Screen.setPenColor(); to set the text color.
You can find all of this information on the VEXcode API reference website: VEX Help
