Hello,
I wrote a simple program that works fine when I download and compile it. However, when I paste the exact program code into a competition template and compile & download the template, the robot doesn’t do anything other than make a slight motor noise.
I’ll paste the code to both the program file and the template file. Any help would be greatly appreciated.
Thanks!
Program Code (Works fine when compiled and downloaded):
#pragma config(Sensor, dgtl1, leftEncoder, sensorQuadEncoder)
#pragma config(Sensor, dgtl3, rightEncoder, sensorQuadEncoder)
#pragma config(Motor, port3, rightMotor, tmotorVex393, openLoop)
#pragma config(Motor, port10, leftMotor, tmotorVex393, openLoop, reversed)
task main()
/Reset encoders to 0/
SensorValue [leftEncoder]=0;
SensorValue [rightEncoder]=0;
while (SensorValue [rightEncoder]<200)
motor[leftMotor]=127;
motor[rightMotor]=127;
wait1Msec(2000);
motor[leftMotor]=0;
motor[rightMotor]=0;
wait1Msec(1000);
while (SensorValue [leftEncoder]<200)
motor[rightMotor]=-127;
wait1Msec(2000);
Template Code (Doesn’t work when compiled and downloaded):
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
#include “Vex_Competition_Includes.c” //Main competition background code…do not modify!
// Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
// Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
// Insert user code here.
wait1Msec(2000);
motor[leftMotor]=0;
wait1Msec(1000);
wait1Msec(2000);
// User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
while (true)
// This is the main execution loop for the user control program. Each time through the loop
// your program should update motor + servo values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to update your motors, etc.
motor[leftMotor] = vexRT[Ch3];
motor[rightMotor] = vexRT[Ch2];
wait1Msec(20);
