Problem with the Battery
we are using six 1.5 volts batterys but they can’t turn on with all the motors plugged in, is there a limit for motors if we aren’t using the 7.2 volt battery? can we use 8 batterys at the same time? we think our charged broked because it doesn’t turn on the light when the battery is plugged.
sorry about any language mistake
Are you using 1.2 Volt NiCd or NiM**H or 1.5 Volt Alkaline cells??? You can not use Alkaline 1.5 Volt cells, because they have a High Internal Resistance, and will limit the amount of Current available to the Motors.
See Thread More Questions??:smiley: about Battery Types.
