Problem with upgrade to 2.0.1
I have a problem with making a firmware update from 1.15 to 2.0.1. The first problem was the service device Virtual COM . The software update does not install the drivers automatically. I installed the driver manually from the directory: Program Files / VEX Robotics / Drivers. In theory it works but when I run an update is detected brain and attached sensors but after the command update error occurs described by karate kid. I tried on several computers Win7 32bit. I tried connected with only the brain.
[quote=“sq5be”]
I have a problem with making [/quote]
Hi sq5be,
Our software team is aware of this problem, and is working on a update for the VEXos utility. We are hoping to push it out live today, if not early next week.
Thank you for your patience,
  • Dillon
