Problems with custom robot controls
This is my first year using vex v5 pro code and I am trying to code using the vex code pro app.
This is my code:
void usercontrol(void) {
          // actual driving
          while (1) {
                  //fowards :)
                  if (Controller1.Axis3.position(pct)  > 0){
                      leftDrive.spin(forward, 100, pct);
                     rightDrive.spin(forward, 100, pct);
                  //back
                 if (Controller1.Axis3.position(percent)  < 0){
                      leftDrive.spin(reverse, 100, pct);
                      rightDrive.spin(reverse, 100, pct);
                 //left
                 if (Controller1.Axis4.position(percent)   > 0){
                 //right
                if (Controller1.Axis4.position(percent)   < 0 ){
I was watching a YouTube Video to help me figure it out but when I put it into the robot and run the program the controller input doesn’t do anything. I don’t know if I am downloading the code correctly* or if my code was wrong/incomplete. If anyone knows how to solve my problem that would be great (or you could just give me the code).
*Someone is going to ask, I download the code by plugging in my robots brain to my computer, and press the save button (the floppy disk in the top right corner) and on the robot run the code from the programs folder.
A problem that you might have is that you haven’t identified what Controller1 is, have not declared the motors in the program, or stated the wrong port.
Also, what your code states is that as soon that you turn your joystick even slightly, your robot will go forwards/backwards full speed and i’m guessing that you don’t want that if you are programming for driving.
here is a video that may help you (minute 6:33 shows the code you need)
https://youtu.be/NtY5oPd0dLQ?si=4Un7_BozRlL-KTZ8
If this does not work could you show us the full code.
